Looking for chimney expert, Long Island
PatchogPhil | Posted in General Discussion on October 6, 2006 04:18am
I am in need of a chimney expert who can evaluate my 1956 chimney. My location is Patchogue, Long Island New York. My oil fired boiler will be replaced next week (99.99% sure it will be a Burnham MPO) and I want to be sure my present chimney is OK. Or will it need a liner or should I go Direct Vent. Any recommendations for an honest chimney technician?
  1. rez | Oct 14, 2006 02:28am | #1
    bump
    "When we build, let us think that we build forever.  Let it not be for present delight nor for present use alone." --John Ruskin Laminate is just a picture of hardwood printed on countertop for your floor.We can imagine something that only exists in our heads, in a form that has no measurable, tangible reality, and make it actually occur in the real world.  Where there was nothing, now there is something.
    Forrest - makin' magic every day
  2. MikeSmith | Oct 14, 2006 02:56am | #2
    if you can get up on the roof and look down the flues you can determine the condition as well as anyone..
    look at  the clay liners.. are they intact or crumbling ?
    is the cap sound ? or cracked
    are the bricks sound or crumbling
    are the mortar joints  solid or crumbling and loose ?
    is the flashing whole or corroded....
    you decide... if any of those need repair... call a  mason.. or fix it yourself
    if the flue liners are shot or non-existent, then you need to get your chimney lined or rebuilt
    if the mortar joints are shot , you need to repoint your chimney..
    if the flashings are caput, you need it reflashed
  3. GUNN308 | Oct 14, 2006 08:12am | #3
    Around here any install requires chimney inspection by fire marshall, get prices for stainless liner and supra-flu if you don't have to replace whole chimney. I'm not a big fan of power vents but they do work just make sure they get maintained every year when your cleaning is done. Call your local fire dept they can probably inspect for free.
    PeteDraganic | Oct 14, 2006 08:15am | #4
    I can do it for you but it might get expensive with the drive in from Cleveland.
    http://www.petedraganic.com/
