Looking for fire-rated material to cover kraft faced insulation in garage (not drywall)
I’m looking for a fire-rated material that I can use to cover kraft-faced insulation in my garage. I will eventually drywall the garage, I just don’t have time to do it right now. I’ve seen a foil faced sheeting with nylon reinforcement in the past that I think will work, but I don’t know what it’s called or where I can find it. Does anyone know of a good product I can use?
Thanks,
Mark
Material to cover kraft paper and pass code
Hey Mark
I see this was an old question and you have probably solved it by now but I recently had the same problem and was given this stuff as the solution.
