Looking for Post Sleeves
shearwater | Posted in General Discussion on August 17, 2007 03:02am
I am estimating a large porch, and I need a source for a PVC post sleeve that slides over or wraps around a 6×6 post.   So far what I’ve found is:
Trademark rail systems makes a 6x, co-extruded PVC/composite, 9′ long.  Price $150/ea.
Advanced trimwright makes a wrap-over sleeve, also about $150.  http://www.advancedtrimwright.com/portfolios/gallery.htm
I could make them myself our of Azek, at a material cost about $100 per unit plus my labor.
With 26 posts in this porch, this is gonna add up.  Does anyone know of anything else – it has to be 6×6 though.  Thanks.
  1. john7g | Aug 17, 2007 03:09pm | #1
    Wrap with aluminum ie aluminum facia material?
      basswood | Aug 17, 2007 11:53pm | #11
      If the 6x6 is ACQ treated, Aluminum cladding is not a good idea (galvanic corrosion).
      1. john7g | Aug 18, 2007 12:01am | #13
        Good point.  Maybe lead?
          basswood | Aug 18, 2007 12:12am | #17
          I'd wrap the posts in durock and "tile" them with bits of broken beer bottles. ;o)
    SamT | Aug 17, 2007 06:29pm | #2
    Have you tried googling "Precast Fiberglass Columns"?
    SamT
  3. djh | Aug 17, 2007 07:09pm | #3
    Try Endurance Rail, http://www.rdirail.com.
    MarkH | Aug 17, 2007 08:25pm | #4
    http://www.hooverfence.com/vinyl/railing/cladding.htm
    1. MikeK | Aug 17, 2007 08:50pm | #6
      << http://www.hooverfence.com/vinyl/railing/cladding.htm >>
      Over $400 per column seems rather expensive. Plus the flutted look may not be appealing to everyone.
        MarkH | Aug 17, 2007 09:14pm | #7
        I thot it was 4 pieces for one price, like a hundred a pop.  No?
        1. shearwater | Aug 17, 2007 11:35pm | #8
          thanks for the suggestions.
          I've used rdi rail - i don't recall a 6x6 but if they've got it, it will work.  Not as fancy as some of the other products, but not bad.
          I'd have to seal & finish MDO really well in a damp, Maine, seaside environment, no?
          Hooverfence looks promising.  So does the alum cladding.
          I'm still leaning toward fabricating them of Azek.  At about $100 for two 18 footers to cover one 7'-4" post, that leaves enough offcuts to make some nice capitals.
            Luka | Aug 17, 2007 11:45pm | #9
            "At about $100 for two 18 footers to cover one 7'-4" post,"Good LORD !!!It's plastic, fer cryin out loud, not gold !!SOMEONE saw carpenters coming, and is laughing all the way to the bank...I've always thought the same about corian. Watching the homeowners go gaga over a plastic countertop, and thinking..."It's plastic folks ! You are oooo'ing and ahhhh'ing and paying a kings ransom, for PLASTIC, ya idjits !"
            Yeh... That'll work.
            MarkH | Aug 17, 2007 11:48pm | #10
            Wonder what copper cladding would cost.
            Sphere | Aug 18, 2007 12:04am | #14
            I doubt any metal wrap would look good for long, any post twist will show up as oil canning or wrinkled up, unless it is floated loose, and then it'll dent easily. I wouldn't do it.
            MarkH | Aug 18, 2007 12:08am | #16
            I doubt copper posts are aestheticallly pleasing on most houses anyway.
            MarkH | Aug 17, 2007 11:59pm | #12
            What about granite?  It's a freaking rock folks!  Why spend so much?  Give me linoleum over pine planks for countertops.  It was good enough for my dear departed granny.
            Luka | Aug 18, 2007 12:08am | #15
            I'll stick with the original plastic.Laminate.
          7. User avater
            MarkH | Aug 18, 2007 12:12am | #18
            Yeah, thats what I have.  It's old and ugly, blends in with the rest of the house.
          8. User avater
            basswood | Aug 18, 2007 12:14am | #19
            http://www.barsandbooths.com/bandblaminates.htm
          9. User avater
            MarkH | Aug 18, 2007 12:18am | #21
            I've looked at that site before.  Cool stuff.
          10. User avater
            Luka | Aug 18, 2007 12:15am | #20
            I wonder how well laminate would stick to the OP's posts ?;o)
          11. User avater
            MarkH | Aug 18, 2007 12:19am | #22
            Laminated PT?  Not so much.
          12. User avater
            Luka | Aug 18, 2007 12:54am | #24
            You didn't see the wink ?Dangit, you were supposed to play along.Now I'll NEVER convince the guy to put 4 different patterns of countertop laminate on each post and trim the corners with that pricey azek stuff...
    MarkH | Aug 17, 2007 08:32pm | #5
    You could make cladding from MDO.
    NickNukeEm | Aug 18, 2007 12:21am | #23
    I've put up a few miles of this company's railings.
    http://fairwayvinyl.com/accessories.htm
    They have 4x4 sleeves, 5x5 sleeves, and 6.5x6.5 sleeves.  They also have vinyl post wraps in 6x6.
    The 6.5x6.5" sleeves are $127 for 108", the wraps are $70 for 8 feet.
    I order the stuff from UBS, and local yard.
    "I am the master of my fate, I am the captain of my soul."  Invictus, by Henley.
  7. retiree | Aug 18, 2007 03:28am | #25
    I installed three 6X6 PVC post covers this past week in Virginia. They were made by a company called LB Plastics out of Mooresville, NC. They were 8' 6" long and are also available in 10'. They came in four pieces and snapped together very easily. No screwing or nailing. The ones I used were fluted, but they are available smooth and in four colors. The product line is named Sheerline. They cost $64.43 each plus the top trim which added $7.73. You can check them out on the web under pvc railings. I was very satisfied with the product.
  8. qtsam2 | Aug 19, 2007 04:49am | #26
    certain teed makes a product snap wrap
    http://www.certainteed.com/CertainTeed/Pro/Contractor/FenceDeckRail/Prodindex/Railing/Evernew/SnapWrapDetail.htm
    1. shearwater | Aug 20, 2007 04:27pm | #27
      I'll pass on the retro bar booth laminates for now, but there's some good links in the replies and several products I wasn't aware of.  Thanks.
Old House Air-Sealing Basics
