Looking for rot proof jambs as part of residential pre-hung exterior French doors
house567 | Posted in Construction Techniques on November 15, 2012 03:09am
Can anyone recommend a door supplier in Houston TX for this DIYer?
  1. MLB_Construction | Nov 15, 2012 07:46pm | #1
    just make one out of Azek.....there, problem solved
    hammer1 | Nov 15, 2012 08:08pm | #2
    I just replaced rotted exterior door jambs but kept the door. I used JenWeld Auralast jambs which are a treated product. If you are replacing the whole door system, you can special order it with treated jambs from most manufacturers. I used Aztek for the kick board and synthetic brick mold for the casings.
  3. DanH | Nov 15, 2012 08:28pm | #3
    A lot of exterior jambs are now available with about the bottom 8" made with plastic, the rest wood.
  4. florida | Nov 15, 2012 09:45pm | #4
    Any door shop can make you frames from vinyl or fiberglas. I haven't installed an exterior door jamb made of wood in at least 10 years. I use fiberglas doors, vinyl jambs, PVC shims, stainless hinges and stainless hinges to put it all together. Nothing goes wrong wiht them short of a hit by a comet.
  • xoxo test post 3
  • xoxo test post 2
  • xoxo test post 1
