looking for translucent shoji material
| Posted in General Discussion on February 10, 2001 01:42am
Hello All
I’m building some shoji – type false window panels w/light behind. I saw a product in some magazine (pos. FHB) that was a translucent, acrylic or plastic that had a ‘rice-paper’ texture and appearance. Can’t use frosted glass. Any thoughts, anybody?
Rob
  1. Ralph_Wicklund | Feb 08, 2001 04:34am | #1
    < Obsolete Link > rob.kelly "Source for fibreglass/rice paper for Shoji screen" 9/27/00 10:39am
    There was a discussion about this a while back.
    1. Ralph_Wicklund | Feb 08, 2001 06:02am | #2
      *Back up atcha. Did you forget you had one out here already??
      1. Mike_Smith | Feb 08, 2001 06:04am | #3
        *kalwall distributes to retail thru mailorder form their Solar Components Corp. in Manchester , NHkalwall makes a translucent fiberglass sheet invarious thickness.. and in insulated panels...1/2 inch to 1.5 inch...lots of shoji screens have been built with it...
        1. Luka_ | Feb 08, 2001 06:18am | #4
          *A palm sander.80 grit sandpaper.A sheet of plexi.Sand both sides.Now go delete that other post.
          1. bobl_ | Feb 08, 2001 04:05pm | #5
            *Lumasite http://www.sweets.com/index/profile.htm?site=undefined&id=1006&pid=22518Lumasite normally used in making signs, 2 types are architectural panels that are used for soji like appearance. These type are sold thru the factory (according to their 800 number) the .09" thikness ~$5/sq ft, .125" is ~ $6/sq ft. Come in panels.There is also a material I believe is called sanskin that comes on a roll. fiberglass impregnated so needs to be sealed I've read. Some have used unprinted Tyvek.Been researching for two projects of my own.
          2. splintergroupie_ | Feb 09, 2001 03:16am | #6
            *Art supply stores carry a large array of hand-made papers with unbelievably beautiful textures and colors. If you want something unusual but sturdy, mount them on the fiberglass with photomount spray-- regular spray adhesive will turn yellow.
          3. Rob_Strom | Feb 09, 2001 03:46am | #7
            *thanks - I considered that
          4. Rob_Strom | Feb 09, 2001 03:50am | #8
            *thanks boblIt looks like the lumasite is the way I'll go. I'm leaving the final decision up to the architect (they like that). I still like the orbital sander on plexiglass - I've used that on a couple different applications - a front door and some custom flourescent covers. Anyway thanks for the infoRob
          5. bobl_ | Feb 10, 2001 01:42am | #9
            *Fax them a letter request and the company will send samples. They won't send samples w/o a fax, won't do it based ona phone call.
  2. Rob_Strom | Feb 10, 2001 01:42am | #10
    Hello All
    I'm building some shoji - type false window panels w/light behind. I saw a product in some magazine (pos. FHB) that was a translucent, acrylic or plastic that had a 'rice-paper' texture and appearance. Can't use frosted glass. Any thoughts, anybody?
    Rob
Outdoor Lighting
