lost vents
gecko | Posted in Energy, Heating & Insulation on July 7, 2005 05:36am
I’m working on a basement remodel and after framing and running new duct work I had my drywaller come in and board and mud the whole place. they sprayed on a textured ceiling treatment. unfortunately they drywalled over a couple of vent openings in the ceiling without cutting them out, or making note of where they are.
does anyone here have any suggestions of a way to locate them in the newly finished ceiling?
thanks in advance, and any answers will help, I’m pretty desperate at this point.
Custom Cabinetry and Furniture <!—-><!—->
www.BartlettWoodworking.com <!—->
  1. DavidxDoud | Jul 07, 2005 05:59am | #1
    turn on the heat or the AC and use infrared imagining to deduce the spots - - don't know if you can rent that kind of equipment or not - - might be able to feel for it,  I'm guessing you have a general idea of where to look -
    "there's enough for everyone"
    1. brownbagg | Jul 07, 2005 06:25am | #2
      that why I took pictures of each wall framing before sheetrock. I know where each outlet, electrical, cable, telephone, hvac is.
      1. DavidxDoud | Jul 07, 2005 06:44am | #3
        a good idea indeed - I've got photos of walls and outside drains and such - now if I just knew where the photos were.....
  2. fredsmart48 | Jul 07, 2005 09:11pm | #4
    using a IR Thermometer with the ac turn on it would show as the coldest spot on the ceiling.  then if you turned off the ac the last spot to warm up would be under the vent.   it should get you close.
    be sure to back charge the rockers for your extra work and expense.
    I have seen the  ir thermometer listed for sale less then $80.00.   -20° to 600° degrees
    Edited 7/7/2005 2:16 pm ET by fredsmart
  3. r_ignacki | Jul 08, 2005 12:31am | #5
    wanna locate em?     Grap your saw and poke and cut.   A hammer works good to. I bethcha thatn aint all that's covererd up either.
      gecko | Jul 08, 2005 02:42am | #6
      I can feel temperature changes where they are but not accurate enough to start cutting into it. the vents are 4"x10" and the area I can narrow it down to is about 24"x72". my initial thought was to use a thermal imaging camera but I have no idea where to find one of those.
      I do have pictures of one of the two lost vents, so I could probably find that one with some educated guesses.
      anyone know where one might rent a thermal imaging camera?
      Custom Cabinetry and Furniture<!----><!---->
      http://www.BartlettWoodworking.com<!---->
      1. davidmeiland | Jul 24, 2005 07:10pm | #9
        Does your fire department have one? Go in, talk to the duty officer, and ask if he will swing by and give you a demo, in return for a nice donation to the firefighters' association.
      gecko | Jul 08, 2005 02:44am | #7
      they didn't cover anything else up. I have a couple access panels for junction boxes but they cut holes out for those. all the other vents they either marked or cut out. I'm pretty sure they did mark the lost ones also, but went and sprayed the textured ceiling before they cut them out.
      1. dIrishInMe | Jul 24, 2005 07:32pm | #10
        Call the sheetrock sub back onto the job?  That's what I'd do... Matt
          gecko | Jul 24, 2005 10:02pm | #11
          thanks for the suggestions guys. what I ended up doing was feeling around on the ceiling for the cold spots (AC was on) then I put a piece of .5 mil wire in my drill and drilled a tiny hole. I then took another piece of the same wire and stuck it in the hole and poked around to see if I could hear metal. I found them both on the first try. if they were return ducts I don't know know what I would have done.
  4. jrnbj | Jul 14, 2005 04:46am | #8
    IIRC, you can get IR film that will work in a 35 MM camera....
Two Ways to Test Windows
  • The New Old Colonial
