Loud noise coming from attic
Mfreeze | Posted in General Discussion on December 5, 2015 06:23am
I have a strange loud banging noise coming from my attic area in one part of the house. Seems to be worse at night after sun goes down or even the middle of the night. Really could use some help. It’s very loud when it happens and occurs once or twice a night typically. Temps are moderate given home is in Arizona. I was lucky enough to catch it on my phone video in attached file near the end of the recording. Thoughts?
https://www.dropbox.com/s/s8qumkrhd19fevx/2015-11-01%2017.56.24.203.mp4?dl=0
  1. DanH | Dec 05, 2015 07:53pm | #1
    Sounds like the rats are playing tennis.
    (Alas, could be anything.  One possibility is that you have a forced air system with remote dampers and one of those is opening/closing.  Another is that it's simply thermal expansion contraction between two fairly rigid members in the structure.)
    (Or it could actually be an animal coming and going through some sort of metal flap.)
  2. DanH | Dec 05, 2015 08:24pm | #2
    Describe the house construction a little bit -- ordinary wood frame?  Metal roof?  Tile roof?  Forced air ducts in the attic?
    1. Mfreeze | Dec 07, 2015 10:42pm | #5
      Lloyd noises in attic
      Wood frame with stucco siding. Flat foam roof. About 3 ft of non accessible attic space. Appreciate all suggestions.
    Mongo | Dec 06, 2015 12:35am | #3
    contraction
    My thought was the same as junkhound's.
    Sounds like duct work or sheet metal cooling down.
  4. Mfreeze | Dec 07, 2015 04:04pm | #4
    Noise in attic
    thx much for all the suggestions. There is some ducting up there and I don't have access to it except to pull all the drywall off. This weekend I lowered the water pressure and installed water hammer devices on the washer lines. House is wood framing, stucco sides and flat foam roof. Attic space looks to be about 3 ft but I have no access. Any other thoughts, please let me know.
  5. florida | Dec 08, 2015 03:21pm | #6
    If you have a fireplace or wood stove with a framed  chase for the chimney you probably have a sheet metal pan on the top of the chase. Since it's so exposed to the sun and cooling night temperatures it can make a loud popping sound as it cools and heats up again.
