low end toilets
ponytl | Posted in General Discussion on January 22, 2009 05:24am
I’ve been shop’n crappers…  and search’n google…. I installed on cheap toilet ONCE… what a piece of
… but the $29 price was all i had at the time…
now i need 40 toilets… i can get an Orion…&
#160; for $42  (in this quanity)  no bad reviews on google searches… I can get a briggs private brand at my supply house for $67 with seat and wax ring and bolts (a $7 value)… what i can’t spend is $200 per… if  was buy’n 1 ok… I’m cool with $400 for one… but  i need 40… and 2k vs  8k  is huge…
any takes on low cost but not cheap?
thanks
P
  1. JoshRountree | Jan 23, 2009 10:11pm | #1
    All of these are out of your price range, but I use this website a lot when researching things. It's kind of like Consumer Reports, except free. It might help you out.
    http://www.consumersearch.com/toilets
    Edited 1/23/2009 2:12 pm ET by JoshRountree
    1. ponytl | Jan 24, 2009 02:44am | #2
      thanks...  i'm still on the fence... i went through my warehouse and found about 8 new Kohler units... not top of the line but $150 or so retail...  so i'm down to needing... about 36 more... I'll pick up one orion this weekend and hook it up and just see how it flushes...  you can tweek a few things to get a little better flush so i'll play with it before i get 35 more...
      thanks for the info
      p
      1. joeh | Jan 24, 2009 04:10am | #3
        Toilet tune ups.........
        Toto are pretty decent for their cheapo.
        Toto is what water departments are usually giving out when they are trading for your old gas guzzler models.
        Joe H
  2. rasconc | Jan 24, 2009 04:26am | #4
    I like Gerber.
    For those who have fought for it Freedom has a flavor the protected will never know.
  3. curley | Jan 24, 2009 05:35am | #5
    I bought a Elijer Titan. Very impressed. Paid $200 at Menards. In the year we've had it , it plugged twice. Six folks flushing the toilet. Also it has a piss mode. A quick flush and you only half empty the tank
    1. ewilliams20 | Jan 24, 2009 06:37am | #6
      quote:
      "what i can't spend is $200 per..."
      quote:
      "I bought a Elijer Titan. Very impressed. Paid $200 at Menards."
      I'm sure this will be very helpful info for the original poster.
  4. alwaysoverbudget | Jan 24, 2009 06:45am | #7
    i think the problem with cheapies is that they are inconsistant. i have one some off beat mexico brand in a rental.that thing flushes like a old 7 gal one.if i had been paying attention i should of went back and bought a dozen of them. i think your method is about as good as it gets,buy 1 try it.
    hd here has some 100. units marked to 49. so you might check them.
    oh,you owe us a review on toliets when your done,i want to know the best for cheap out there also.
    if i spend 600. on a flusher it better do more than flush good.
    YOU ONLY NEED TWO TOOLS IN LIFE - WD-40 AND DUCT TAPE. IF IT DOESN'T
    MOVE AND SHOULD, USE THE WD-40. IF IT SHOULDN'T MOVE AND DOES, USE THE
    DUCT TAPE.
    1. gotcha | Jan 24, 2009 07:19am | #8
      kidnap....
      I get real estate info from Wichita...Weigand Realty
      This should get you to an ad for rental property.Petehttp://us.mg1.mail.yahoo.com/dc/launch?.rand=0dt5ttkf8tea4
      1. alwaysoverbudget | Jan 24, 2009 07:29am | #9
        takes me to a yahoo site???? larryYOU ONLY NEED TWO TOOLS IN LIFE - WD-40 AND DUCT TAPE. IF IT DOESN'TMOVE AND SHOULD, USE THE WD-40. IF IT SHOULDN'T MOVE AND DOES, USE THEDUCT TAPE.
  5. qtsam2 | Jan 24, 2009 07:34am | #10
    IIRC you don't like Home Depot...... but with that being said if you found a decent toilet you liked, tell the Contractor Desk to quote you 40 and send it to the Bid Room and I think you might be surprised at what you could get them for.
    1. ponytl | Jan 24, 2009 07:44am | #11
      i thought about  that... the HD bid room...  thnk i posted 2 weeks ago when they had a bid room special for 12ga 500 ft rolls of wire pallet price $23rl  shelf stock was still @ $55... today the shelf price is $40rl...    you know they were make'n $ @ 23  so... not retail @40...   don't know if they have that kind of room in toilets  but... it is telling...
      HD has several toilets in the $89 to $100 range... don't know if they can get to the $42 i was quoted on the ORION...plus $1 for the wax  .79 bolts & $4.79 for the seat... then they will give me a 5% discount off that total...
      I'll pick one up in the morning... hook it up.. and see what i can figure out to do to "TEST" it.....  Gunner.... where is Gunner when you need him
      P :)
  6. BrianDerr | Jan 24, 2009 07:57am | #12
    You know when I use a toilet, I don't think I notice how much it costs. But there are a couple of things that bug me that maybe could be avoided on even a cheap toilet. Bowl size: the larger and more elongated the better. the smallest ones just seem unsanitary, inconvenient and stupid. I don't think there is a problem with skinny people sitting on a slightly bigger bowl. Bowl hieght: too low just makes me feel like I'm in potty training, and i'm not even a very big guy. I'd like to move the market away from these 'bad' toilets.
    Brian
      johnpjackson | Jan 26, 2009 01:24am | #14
      Speaking of toilet peeves..There's a toilet design out there with the hole that the bowl drains from shaped into a square angle at the 12:00 position (if you're standing in front of the bowl looking down into it). The problem? Unless they start making plungers with a matching square angle included in their circumference, whenever you try and plunge such a toilet that right angle leaves an opening between the edge of the plunger and the bowl's drain hole that allows the contents of the bowl to be ejected straight upward at you when you push down with the plunger.What brain-dead design engineer didn't consider or didn't care about that?:(
  7. User avater
    dogboy | Jan 26, 2009 12:17am | #13
    Low end toilets says it all.
    Carpentry and remodeling
     Vic Vardamis
    Bangor Me
  8. brucet9 | Jan 26, 2009 01:41am | #15
    Kohler Wellworth comes in well below your $200 threshold at regular pricing from HD. They look ok, no special parts for repairs and they work well.
    Probably better pricing from HD for 40 of 'em - maybe even less at a wholesale plumbing supply.
    BruceT
    1. ponytl | Jan 26, 2009 01:55am | #16
      i have checked everything on the net that i could find....  a gravity feed 1.6 gal toilet... seems to be a #### shoot (no pun)  none stand out... and price doesn't seem to affect how well it performs... you can spend $400 or $40 (from published reports) and get equal performance...  the only factor it seems that matters is flapper size (the size of the port at the bottom of the tank...  2" seems to be standard... but there 3" and 4" ones... if you are use'n 1.6 gallons... it's a toss up... a longer flush with a 2" or a fast short flush with 4"...   pros to both....negs to both....
      I have 2 upper end units at my house  purchased/installed at the same time... one has always perfromed better than the other.... don't know why...
      I'm going to play with one monday the $42 orion.... just to see...
      p
      1. brucet9 | Jan 26, 2009 02:09am | #17
        I don't know just what to think when a guy says he's going to play with a toilet... :)BruceT
        1. ponytl | Jan 27, 2009 03:05am | #19
          just doesn't take alot to amuse me....  :)   as witness my time spent here... <g>
          p
      2. Snort | Jan 26, 2009 03:14am | #18
        I think I pay my plumber about $125 for a Toto Drake, buying 3-4 at a time... 35 ought to get a great price for a trouble free hole in the floor.http://www.tvwsolar.com
        I went down to the lobby
        To make a small call out.
        A pretty dancing girl was there,
        And she began to shout,
        "Go on back to see the gypsy.
        He can move you from the rear,
        Drive you from your fear,
        Bring you through the mirror.
        He did it in Las Vegas,
        And he can do it here."
