Low overhead deck conection to concr…
| Posted in General Discussion on August 13, 2001 11:07am
In my county of Northern Illinois code is that all decks wether connected to the house or not require a 42″ minimum concrete frost column.
The grade in the area is 12″ from top of foundation. What type of connection should I use to attach the beams to the top of these concrete columns as they will basically be resting right on top. I looked through the Simpson book but could not find anything specifically for this.
  1. Jon_Blakemore | Aug 13, 2001 11:07pm | #1
    Gerard,
    Try using a post base. Most post bases are 3-1/2" wide so you can use a double 2x beam with 1/2" plywood spacers to give you 3-1/2". The spacers will help you get airflow around the beam which will prolong it's life. Remember to cur the tops of the spacers at a 15 degree or so angle to facilitate run-off. Good luck.
    jon
  2. Gerard._D | Aug 13, 2001 11:07pm | #2
    In my county of Northern Illinois code is that all decks wether connected to the house or not require a 42" minimum concrete frost column.
    The grade in the area is 12" from top of foundation. What type of connection should I use to attach the beams to the top of these concrete columns as they will basically be resting right on top. I looked through the Simpson book but could not find anything specifically for this.
