I am in the process of remodeling my home. and as part of the job I am converting an existing covered porch into living space. The space is approx 8’x21′, I broke out the concrete slab, removed the fill and will be using the existing concrete block foundation. I want to use the existing roof structure ,2×6 rafters spanning 8′ and pitched a little more than 1 in 12. When I pulled off the plywood porch ceiling, everything looked good, solid roof decking, no sign of leaks etc. The current roof is standard 3 tab shingles at least ten years old. When I re-roof is it o.k to use the 40 yr asphalt architectural shingles that Ive been usingon the rest of the house if I double felt first? I seem to remember seeing a product similar to ice and water shield, self adhesive and I think reflective, that was made to be a finished roof rather than an underlayment. Anybody know anything about this stuff? Finally, when I finish off the interior of the room does this roof need to be ventilated? Its a shed roof attached to a gable wall. There will be no “attic” space. The rafter bays will be insulated and the finish ceiling product will be fastened directly to the rafters. Ventilate some how, vapor barrier on interior side of rafters? Any and all replies appreciated
Upgrading the footings and columns that support a girder beam is an opportunity to level out the floor above.
One roofing material that I know of that is specifically for low slope roof is a product ironically called Lo-slope by a company Monsey -something or another. It just sticks down like ice and water shield with the help of a tube adhesive along the edges. Easy to work with and a major improvement over old roll roofing.
As you probably already know shingles are not recommended for roofs lower than 4-12. Personally I would go a different route with a slope that low, even with a layer of ice and water shield, but roofing is not my area of expertise either.
Without a doubt it should be ventilated. Soffit vent with insulation baffles all the way to a vent along the wall roof intersection (you can get this specific vent just about any where)
Thanks for the reply,Scott. I'll do a search on the web or try my local supplier for Lo-slope. Happy 4th
Two reasons not to re-roof with these shingles on a low slope such as this:
>>Thet have a laminated seam at the midline that is more likely to open up under ice conditions so you can't count on headlap to help prevent leaks. Commonly, a standard shingle would be installed at 4" exposure on a low slope to increas headlap but that doesn't help with these and it can cause other problems with them.
>>As you now enclose this space and add winter heat under a roof that previously had thermal stablity, top to bottom, you increase the odds of condensation and ice dams. These rafters barely give you enough space for insulation so I would add a layer of foil faced Thermax to the underside also.
I would use the typ of product discussed above but if you are dtermined to shingle for the look, You would have to use ice and water shield on the whole area.
Thanks for the advice, I'll check my supply house for this Thermax product. Dont need to shingle for the look so Ill use the lo slope or similar product. Do you also feel that the roof should be vented at the soffit and where the shed roof meets the sidewall? Thanks again
Normaly I go for vents in a roof, but the only way for them to work is if air can flow from soffit to ridge for total ventilation. If you fing it hard to get the flow through, it's probably best not to vent this one and seal the ceiling instead. Tape the foil faced foam seams, caulk penetrations, and use good paint. If this is a north facing roof in an extreme climate and this room is a sauna or bathroom then all bets are off.
Just curious - Wouldn't snow piling up against the upper vent pose a serious problem? Melt would run right into the vent and into the ceiling?
- WebTrooper -
I meant it would have to vent through to the ridge vent.Excellence is its own reward!
FWIW, I saw something that seemd to be single ply membrane vents for the first time a week or so ago: looked like the attached photo:
Thanks again to all for the feedback.
