lowes deal for today PL glue
ponytl | Posted in Business on May 16, 2009 06:29am
PL all purpose liquid nails glue… 5 for $5  regular i think about $2.67 a tube… buy it by the 12 pack and they knock another 10cents  off each tube make’n it 90cents a tube…
not to bad if you keep it on hand or have a need for it…  i only picked up 2 cases… but sure I’ll wish i’d gotten more
think you hve til the 25th of may for the deal…
p
Edited 5/16/2009 12:17 am ET by ponytl
  1. rez | May 16, 2009 06:35am | #1
  2. Piffin | May 16, 2009 01:40pm | #2
    Which is that?
    I didn't realize PL had an all purpose?
    I'd like to read the online description before going out of my way to buy it and finding it inappropriate for what I do.
    http://www.stickwithpl.com/ProductsList.aspx?ID=PANEL-CONSTRUCTION-ADHESIVES
    I just can't find that particular product.
    Edited 5/16/2009 6:45 am ET by Piffin
    1. ponytl | May 16, 2009 03:56pm | #4
      man... you made me run out into the rain and get a tube out of the case JUST so you could know what i was talk'n about....  wow..
      it's pl375  it shows on your link as a new product....
      guess i'll pick up a few more cases...
      hope that helps... there are no wasted trips to building supply/tool places
      p
      1. Piffin | May 17, 2009 12:27pm | #10
        see there, it's a new product! No wonder I didn't recognize it. PL might be participating in this sale to help get it known.
    IMERC | May 16, 2009 03:33pm | #3
    is it PL or LN????
    WOW!!! What a Ride!
    1. ponytl | May 16, 2009 03:57pm | #5
      pl375  it shows as a new product on their website
        IMERC | May 16, 2009 04:31pm | #6
        thamks...
        but which version of PL375????
        ROAR!!!
        WOW!!! What a Ride!
          BillHartmann | May 16, 2009 09:55pm | #7
          Lowes for Pro's has this listed."5 for $5
          PL Heavy Duty
          Construction
          Adhesive
          Discount taken at the Register
          Item #: 144243 or 153955 Offer valid 5/14/2009 - 5/20/2009"I could not match that description or item numbers to anything that they show online. But that is not that unusual.And there is not coupon. Usually for those deal you need to print out a bar code coupon.http://forpros.lowes.com/And you need to register to get to the specials..
          1. ponytl | May 16, 2009 11:48pm | #8
            they just have a green sign posted next to the product... says 5 for $5     so i picked up 2 cases ie...24   they rang up @$1  and then gave me a 10cent discount per tube for buy'n the full case... so 90cents per...   on the grenn tag it lists 2 sku numbers  but i could only match up one... with what they had...
            no coupon...
            p
          2. Piffin | May 17, 2009 12:37pm | #11
            I looked at the sheets on it to see if it would handle foam. It is not clear about that, but it has MA, naphtha, and acetone VOCs so probably not. Let us know how well it works compared to others.
            IMERC | May 17, 2009 04:04am | #9
            thanks Bill...
            WOW!!! What a Ride!
          4. Piffin | May 17, 2009 12:39pm | #12
            I wondered which one at first too, but they just listed it twice at the page I linked. Once as a panel adhesive and once as a heavy duty const adhes
            Dam_inspector | May 17, 2009 03:15pm | #13
            Then there is both regular and low voc, same part number.
          6. Piffin | May 17, 2009 03:18pm | #14
            it was low voc 375 I was looking at.
          7. User avater
            Dam_inspector | May 17, 2009 03:23pm | #15
            Their website is pretty generic with descriptions.
          8. ponytl | May 17, 2009 05:27pm | #16
            it says on the tube... bonds all common building materials...    I'm not as professional as you guys... I use what i have  without ever reading too much...  man i have used it (liquid nails type products) for caulk if i knew it was to be painted... and years later it's still good...
            the water based latex liquid nails stuff is the only product in this family of stuff i stay away from... it doesn't stick even though it does suck...
            p
FHB Podcast Segment: Roofing on Commercial vs. Residential Buildings
In certain scenarios, flat roofs make more sense than pitched roofs (and vice versa).
  • A Postwar Comeback
