Lowes top choice white wood 1×4’s vs. 5 quarter cedar “deck boards”
atvalaska | Posted in General Discussion on March 23, 2011 02:51am
Ok which  way would u go, I use the 1×4’s  1 foot on center going up the roof 6/12 pitch (on 24” on center trusses) as the backer for my metal roof (on my house/s my 3rd) I found I can get the cedar  cheaper..near as I can tell its  better, cleaner and straight , what do u folks think of using the 5/4 boards ..strength wise, screw holding etc..
    hammer1 | Mar 23, 2011 04:10pm | #1
    You use skip sheathing under metal on a house?
    1. atvalaska | Mar 23, 2011 04:59pm | #2
      i've only seen it done- "fully sheated "one other time. roof needs Lots of air flow in these parts
        hammer1 | Mar 24, 2011 09:16am | #3
        What about 2x4s?
  2. duradeknw | Mar 24, 2011 05:44pm | #4
    Lowes top Choice White wood vs 5/4 cedar
    White wood (SPF or  spruce, pine, true fir)  is  weak on holding screws or nails.  The strength in fastener holding is specific to the hard dark fiberous wood or growth rings and density thereof.  White woods carry very few hard fibers, thus white wood,  as well as some 2nd growth cedar.  My preferance in Douglas fir, a false fir, for it has a much greater holding power, rot resistance, span ability, load patience and modulus of elasticity  performance than SPF or  fast grow cedars.  Hemlock 's holding power is simular to cedar's, spf is much lower, you do get what you pay for in wood.
    In addion, spacing of  lumber for sweating and breatabilty will affect uplift performance therefore the stonger the pullout of the fastener the better your roof performance.  Plywood is commonally nailed down at  8 inch oc on the joist, trusses or rafters with 8 penny nails, so as a guide figure the amont of nails the plywood has or would have and mirror that amount for your lumber, and again for your metal.  Use 1- 1/2 inch longer nails or screws than the wood you are fastening.  Here I like a good ringshank nail like National Nail.
    WASHINGTON ALASKA ROOF SYSTEMS, INC - Duradek Northwest
    1. atvalaska | Mar 25, 2011 12:08pm | #5
      thanks ,i will check out a piece of the ceder and run some screws to her....the 1x4's at lowes scuk (i do belive ) since the last vast amount of 1x4's i got at SBS in the mid-90's ..was better lumber
A Practical Perfect Wall
  • The New Old Colonial
