Hey anyone, I am considering a tube type gas radiant heater for my currently unheated shop, and want to know if lp is an option. my shop is 32X32X18, metal, and I will be upgrading the insulation from nearly none to spray foam this spring. It will be heated only intermittantedly when I have a project out there. I got a bid from a dealer, but he hasn’t returned my inquiries on which type of gas. I have access to a 600 gal propane tank and have a n.g. line already in place (took out hanging heaters a few years back). The dealer recommended (2) 45k btu self contained units. They require 11 to 14 inches of W.C., but I don’t know how the btu’s and pressure relate to gallons of capacity. Is this tank adequate? I would really prefer to use propane, our local gas co. here is the pits, and just keeping the gas connected over the summer and other non-use times would run about $45 per month, let alone when I am actually using any. TIA for anyone who can help me with this. Bowquack
Bow,
Your 600 gallon tank is more than enough, a 150 would work. Depending on the distance the tank is from the shop you make have to double stage and use two regulators. The fact that the dealer specd 11" wc tells me these are propane heaters.
Make sure the regulators and orifices on the heaters are correct.
KK
600 gallons of LP is a lot of gas--more than enough for the purpose you intend throughout the entire winter.
Say your tank was 80% full; that would convert to 480 gallons, or about 2500 lbs. In turn, that converts to almost 53 million BTU's, enough to run both your heaters for about 580 hrs.
As for the pressure requirements, LP has to be regulated down to those pressures--there will be plenty of pressure, and the installer will need to supply the proper pressure regulators to reduce tank pressure to the needed appliance pressure.
Be sure you check with any local authority to make sure that a tank that large can be placed where you want it. There are usually required setbacks from buildings and property lines.
Weight would be just over 2,000 pounds (approx 4.24 lbs per gallon depending on temp)
My source of info was a site sponsored by the province of Ontario, and gave the weight/gallon as 5.1 lbs @ 60 degrees. Other reliable sites give the same number you used.
Just shows you can't trust Canada. ;-) Or, maybe gravity is stronger up there.
Gallons are bigger in Canada.
I remembered that after posting, and knew somone would call me on it. I expected a Canadian, though. :) When Canadians say gallons, they mean English gallons, which are about 25% more than American.
On the positive side, an English pint is 20 oz,, so you get a good glass of ale when you ask for a pint.
Do be aware that in extremely cold conditions (beginning in the -35 to -40 degree range) propane begins to have trouble vaporizing. Not enough to cut off your gas entirely, but perhaps enough that you could only run one heater at a time.
I don't know if it commonly gets that cold where you are, but I thought it was worth mentioning.
Thanks for the responses. I have checked with the local authorities and there is no prohibition to having a tank that size in town, providing it is properly inspected and protected (I have an ideal location for it). Although it feels like it, we haven't gotten quite that cold here in Nebraska lately, unless you count the windchill!
NFPA requires a min. distance of 10' from a building or property line for tanks over 120 gal. You'll need to purchase the high and low press. regulators and have your gas supplier perform a safety inspection and pressure check of your installed system. You should save from $0.20 to 0.10 per gal. by owning your own tank and regulators, plus you can shop for the best price. In this part of the midwest, natural gas is the least expensive fuel on a delivered therm basis and we have few that stay w/fuel oil or propane if natural is available.
