ANyone have any LP Smartside that has been installed and painted for a while ? I am getting ready to reside my garage and have decided to use the LP Smartside to replace the T111 that is on it now. LP recommends a acrylic latex paint. Just curious if any of you have any specific brand you have used and know of good long term results ? I will probably use something from Duron unless someone telss me otherwise 🙂
Thanks in advance,
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
LP Smartside is a composite siding that's probably similar to the Masonite Woodsman siding we have. We've had excellent results with Benjamin Moore's semigloss exterior acrylic latex on the Masonite.
A builder building in the same neighborhood as where I'm building is using LP smart side. The siding is an OSB type product. Maybe different components of it are masonite type stuff...
OP: I'm not sure you will find info on long term paint performance on LP Smartside. I think it has been out less than a year.
Edited 11/17/2008 7:02 am ET by Matt
Here is some pics I took at the job site... I'd say it's an OSB product.... One thing that is nice about it is that it hangs flatter than Hardie. On the down side the directions call for some pretty large end gaps. I think it's 1/8th. The builder said he was gonna have it caulked twice... The fascia and soffit material had been laying out in the weather for 3 months. It showed some minor degradation....
It's got a strong warranty, but personally I wouldn't trust it, and although I'm into new methods and materials, I prefer not to be on the bleeding edge - but that is just me....
When we did our house with Masonite we used the aluminum joints and corners, vs caulking. Still had to caulk around windows and doors, where the specs called for 3/16 or 1/8 (can't remember which). Had no trouble doing that in one "squeeze". The gaps in the picture look larger -- closer to 1/4".If I had to do it over I wouldn't change any of it -- the siding, the joints and corners, the paint -- all worked out well.
The only function of economic forecasting is to make astrology look respectable. --John Kenneth Galbraith
I think the masonite type products are/were fine as long as they are installed, painted, and maintained properly.
I think there were also several different products, some Masonite brand and some other brands, and durability differed between the products. The stuff we put up was so hard that we pre-drilled most of the nail holes.
