Lube for Garage Door Hardware
spclark | Posted in General Discussion on March 6, 2015 11:35am
Anything special?
Different products for rollers / tracks / hinges?
Maybe something that’s not gonna stiffen up when it gets below 10°F?
Or tend to creep onto the track outsides when it gets above 90°F?
Drive’s a toothed flexible belt that appears to be in good shape. It’s the metal parts I want to keep working freely.
  1. DanH | Mar 06, 2015 02:54pm | #1
    I have seen special products for openers.  There are squeeze tubes of grease, and at least one brand that is a "push-up" stick of grease you rub onto the slider and gears.  But any reasonably heavy-bodied grease will work.
    They don't need much.  Generally, apply grease to the gears and slider every 5-10 years, and maybe every 10-20 years put a squirt of fairly heavy oil into each roller bearing in the door track.  Oil the hinges then too.  If you have chain drive, apply heavy oil to that every 5-10.
    Don't put anything on the belt or its cogs -- grease/oil is not good for them.
Fast, Accurate Wall Framing
