Lubing a Makita LS1013
Scott | Posted in Tools for Home Building on November 10, 2009 05:26am
Makita 10″ SCMS
Any need to lube the drive gears on this unit? It’s sounding a bit rougher than when I bought it (10 years ago), but not terrible.
Thx,
Scott.
  1. RedfordHenry | Nov 10, 2009 06:04am | #1
    This is a direct drive saw, no gears to lube.  Any wobble to the blade?  If so, maybe bearings?  Ever change the brushes?
    1. Scott | Nov 11, 2009 01:36am | #3
      I'm pretty sure mine has gears. The motor is on a 45 degree angle from the axis of the blade. Maybe different years were made differently. IIRC I got mine in 1999.There isn't any wobble, just a bit of mild "knashing" for lack of a better term. It doesn't sound like anything is about to go sideways, but if a bit of lube would help I'd do it.Thanks,Scott.
      1. RedfordHenry | Nov 11, 2009 02:18am | #4
        Yep, you're right, there is a bevel gear in there. Here's a link to an exploded view. http://www.ereplacementparts.com/makita-ls1013-miter-saw-parts-c-97_98_99_100.html
  2. Karl | Nov 10, 2009 06:58am | #2
    I had the bearings go out in my 8" hitachi scms. They were easy to replace with new bearings from the electric motor store.
    karl
  3. allenschell | Nov 11, 2009 02:23am | #5
    I've replaced my gears several times, they will eventually sc ream
    so loud it'll blow your ears off, I don't know if adding lube will
    help. Ask your friendly mak serviceman.
    1. Scott | Nov 11, 2009 07:33am | #6
      When you say, "Replaced the gears", did you need to buy an entire armature assembly, or are the gears replaceable separately?BTW, thanks Red for the diagram.Thanks,Scott.
      Edited 11/10/2009 11:34 pm by Scott
      1. allenschell | Nov 11, 2009 02:37pm | #7
        well I should first say that mine is the older model 1211,
        the Mak dealer replaced the gears.hope this helps, Allen
FHB Podcast Segment: Roofing on Commercial vs. Residential Buildings
In certain scenarios, flat roofs make more sense than pitched roofs (and vice versa).
  • A Postwar Comeback
