Lubricating FERNCO fittings
johnnyd | Posted in Construction Techniques on February 27, 2004 08:41am
What do you use to make FERNCO fittings a little easier to slide on? Dish soap work?
(Probably says in the instructions but my eyes are too old for that)
  1. davidmeiland | Feb 27, 2004 09:43pm | #1
    Yeah, Palmolive. Can't get those things on without.
      johnnyd | Feb 27, 2004 09:56pm | #3
      Thanks guys...yeah, especially 4".
  2. csnow | Feb 27, 2004 09:51pm | #2
    K-Y
    1. davidmeiland | Feb 27, 2004 10:40pm | #4
      If you've got K-Y in your toolbox you might want to keep it buried under some stuff, wrap some tape around it... something... keep it out of sight.
        IMERC | Feb 27, 2004 10:44pm | #5
        Makes working with some less painfull...
        Or you wouldn't want a line at your tool bucket waiting to borrow it...
        1. rasconc | Feb 27, 2004 11:05pm | #6
          I guess it helps when you hear BOHICA.
            IMERC | Feb 27, 2004 11:11pm | #7
            EXACTLY....  ROAR!!!!!
      2. 4Lorn2 | Feb 28, 2004 02:31am | #8
        Used to keep condoms in my plumbing kit.
        On a drain line where it is not possible to dry it I would lash, python knot, the condom onto the end of a length of tubing. This I would insert into the pipe and blow up with lung power and plug the end with a golf tee. This allowed me to dry the area where I was working. Made gluing a lot easier and more of a sure thing.
        I would thread the tubing into the pipe I was adding. After everything was set I removed the tee allowing the condom to deflate. The assembly was then pulled out allowing the water to flow normally.
        I had tried a kids balloon but the condoms inflated easier and sealed tighter. The condoms raised a few eyebrows. I can't imagine what adding K-Y to the picture would cause people to think. I would have to keep both in my handy Crown Royal drawstring bag. Ummm ... maybe not.
  3. ccal | Feb 28, 2004 03:03am | #9
    Spit usually works for me.
