LVL, Paralympic, Or Glulam, Need help! Please
BillRn | Posted in Construction Techniques on October 10, 2018 02:08am
Good Afternoon,
     My house is 36’ wide from exterior wall to exterior wall.  I want to remove a partial load bearing wall.  The wall has 2x8x14 ceiling rafters to one side and on the other side, it has 2x4s that make up a volume ceiling within a gabled roof.  I want to take down the wall between the kitchen and the living room.  The wall is 17’ that I want to remove. Need help in size of Laminated beam to use. To replace wall?
Thanks Bill
  1. DanH | Oct 10, 2018 05:03pm | #1
    You need an engineer.
    mikeljon | Oct 10, 2018 07:13pm | #2
    there are these professionals called engineers...
    You've got way too many variables going on and you need someone who can identify the loads and design a proper beam and load path, connections, etc.
