LVL’s too wide for hanger ????
xtal_01 | Posted in General Discussion on October 5, 2021 11:14am
I have 5 places where double LVL headers tee into double LVL joists.
The literature, LVL’s should be 1 3/4″ thick.
Thus a double should be 3 1/2″ thick
I choose a Simpson hanger that was  has a 3 1/2″ pocket.
Problem .. when I measure my LVL’s, they are 1 7/8″ think … thus a double is 3 3/4′” thick!
I called the company and they just chalked it off as manufacturing variations and moisture (weather conditions) and ….
OK so that does not help … a 3 3/4″ double will not fit into a 3 1/2″ pocket.
I can’t be the only one with this problem … what do you guys do?
I could shave down the LVL to fit it  …. or I could get a 4″ connector and pad it by 1/4″  ….
Just a bit lost ….
Thanks …. Mike
  1. andy_engel | Oct 06, 2021 06:17am | #1
    Most framers shave the LVLs down a bit. I'm not sure how that plays with the manufacturer's instructions though. To be sure, I'd contact the LVL manufacturer.
    1. xtal_01 | Oct 06, 2021 09:38am | #2
      I contacted the manufacturer ... they said I can shave it down as long as it is not "too much".
      They didn't really say what too much is but they said it if it only an 1/8 off each one ( don't take a 1/4 off one and nothing off the other) then I would be OK.
      I knew others much have this problem ...
      They gave a bunch of reasons this happens ... moisture ... manufacturing ....
      Just wanted to make sure I was not hurting the strength of the LVL .
      It is way over rated anyway ... I am only at 50% of the load rating when loaded to the max. The TJI's beside them would fail first.
      Thanks!
      Mike
      PS ... I also contacted Simpson .. they said the same thing ... shave it down or pad it out.
