What would be better for a 600 foot main water supply run through semi rocky earth, sch 40 pvc or pex?
Natural light, taller ceilings, and more functional spaces transform this midcentuary-modern home.
Pex or Type L copper
PEX A or B? IM having a hard time finding PEX A in 1.5 inch
One other thing when you bury the pipe lay down crushed rock first and tamp it; then some sand; then the pipe; then some more sand; some more rock; tamp it then soil. If anyone has to dig later it's nice to know when you get close to the pipe.
Thank you for the info Bing.
Another thing in case of plastic pipe, tape a copper locator wire to it.
Thanks for your time and reply Calvin.
Shoot Meat, I’m retired. Time is what you make it.
That's $6000 worth of copper. I'd use PVC
Pex yes PVC no
For a 600-foot main water supply run through semi-rocky earth, PEX is generally a better choice than SCH 40 PVC. PEX's flexibility and resistance to ground movement make it more suitable for such conditions.
schedule 80 pvc is pretty tough
I would not drink from PVC on a continuous basis. Great for irrigation not potable water
I might no longer drink from PVC on a non-stop basis. Great for irrigation not potable water
