Make any sense to use a used (free) central A/C unit?
Mpls1921 | Posted in Energy, Heating & Insulation on September 28, 2010 05:29am
My parents are having their forced air furnace replaced due to some cracking that the current one apparently has in the heat exchanger.  They are getting a new AC unit at the same time “because it’s cheeper to do it at the same time”.
My house has a central AC unit (Coleman Presidential II) that appears to be from the 80’s.  The many of the fins on the unit are substatially bent.  When it turns on, I picture the scene from Christmas vacation and Clark powers up his lights (and the power company powers up the Aux Nuclear Reactor).
My parents current AC unit is from the mid 90’s and has a scroll compressor.  It is a 2.5 Ton unit, I don’t know what I have on my house now but when I got a quote from a Trane dealer in the neighborhood, he quoted me for a 2.0 ton unit ($2700 for a 14 SEER).
I was sort of thinking to myself, :Self: what if I took my dads old unit and had someone install it at my house.”
Probably doesn’t make sense, but I just thought I would throw it out here for some comments.
 By the way, my $1500 energy tax credit is almost used up already from some other things, so that is not a factor.
Erik
  1. JTC1 | Sep 29, 2010 08:11am | #1
    Unit size
    Take this with a large cube of salt since sizing of A/C units is certainly not a strong point of mine.
    DanH brings up a critical point - your Trane buddy presumably did the sizing calculations and arrived at a 2 ton unit for your home.  Your parents "free" used unit is 2.5 ton, a 25% larger unit, but probably more energy efficient - guess based on age alone.
    Humidity in your area would be the prime consideration -- the effect of a "too large" unit in a humid climate is that the unit cools the house too quickly and thus does not remove humidity effectively because of a too short cycle time.
    If your climate is dry, the larger unit will probably be OK, if you live in a humid climate you will end up with a cool, but clammy house with an oversized unit. Completing your forum profile would help.......
    Might want to get another opinion on the sizing.
    Jim
  2. DanH | Sep 29, 2010 08:29am | #2
    By the way, if you can find the nameplate on your unit and it isn't too badly faded it will likely quote its tonnage and SEER.
  3. Amish Electrician | Sep 29, 2010 03:40pm | #3
    What refrigerant is used?
    IMO, it makes NO sense to re-use a unit that was intended to use something that will become obsolete in, say, the next ten years.
    Moreover, there has been a significant improvement in efficiencies (SEER) over the past five years - so you may be better off with a new unit anyway.
    1. Mpls1921 | Sep 29, 2010 09:07pm | #4
      I had considered the possiblity of short cycling.  I can't seem to find the ton rating for the current unit, the tag I found gives the draw for the compressor and fan, model number, etc, but I don't seen anything about the capacity.  given the condition of the unit, I'm not sure it is exactly relevent anyway.  When it's hot enough for me to use it (90+F), it runs pretty much constantly.  Humidity is a factor here (Minneapolis, MN).
      I have no idea what it would cost to transport it to my house and have it installed.  Given I can get the 14 SEER new unit for 2700 and the 13 SEER unit for 2400, I don't think it would be a good idea if it cost me more than say $500 in labor to install my dads unit.
      SInce I only use it when its really hot/humid, I am leaning to dropping the idea, and just sucking it up and paying for a new unit when the current one bites the dust...
      Thanks for the comments, always very much appreciated.
      Erik
