make my own pebble dash stucco, help
scooleen | Posted in Construction Techniques on December 27, 2005 06:21am
Okay, anyone have some advice on pebble dash stucco? Anyone made it before, and if so I would like to hear your recommendations on how you made yours.
From what I have seen, you make the stucco using the sand, lime, and portland, mix up two or three coats, even up and then throw the rocks onto the aggregate?
    razzman | Dec 31, 2005 07:38pm | #1
    bump
    'Nemo me impune lacesset'
  2. ELoewen | Jan 01, 2006 02:57am | #2
    pebble dash has become popular here in vancuover recently,
    so i've had a chance to observe the application of it
    1st scratch coat, just enough to cover most of the mesh
    second coat, section a time, then while still soft throw the pebbles on with a small shovel like tool (6x6 3 sides with edges, short handle)
    pebbles were either damp or
    mixed in the mixer with a small amount of a cement mixture to make them sticky
    they tell me it takes a bit of practice to get it even
    1. notascrename | Jan 01, 2006 09:23am | #3
      I talked a stucco cont. into trrying it and we used a modified exposed aggrate approach. got the base coat on, applied a fairly thick second coat while the pebbles were in the mixer in concrete slurry, threw the pebbles on[ let my girls write their names w/agate] let it set a little ,sprayeds it with retarder, came back the next morn amd scrubbed off the portland with wateer and a stiff brush. worked great. still kicking around whether seal or not. jim
      1. scooleen | Jan 02, 2006 04:44am | #4
        I thought you did the scratch coat, then lay mesh, then stucco over the mesh second and final coats, does that sound correct?
        1. ponytl | Jan 02, 2006 12:09pm | #5
          no mesh mechanically attached (ie nailed) scratch coat over the mesh...
          p
