Making a fan design with clapboards ?
royr | Posted in Construction Techniques on October 27, 2002 01:08am
On my back porch gable ( 16′ L x 10′ W @ a 7 pitch I want to side it with clapboard in a fan type pattern. Any good sites or books out there on this? I helped on one about 15 years ago and don’t remember the procedure. The rest of the clapboard on the house is on a 4.5 inch reveal.
Roy
  1. xMikeSmith | Oct 27, 2002 01:27am | #1
    rupert .. 1st you need a half circle central hub...
    lay everything out to scale .. a 1/2" = 1 ft. is good.. the central hub might be 32" wide x 16" high
    start at the bottom with horizontal courses, 2d course might taper from 2.5 at the hub to 4.5 at the ends... strike 2.5" arcs around a paper pattern of your hub to see what will work out.. ( 2"  ..... 2.25"  ...2.5" etc )  the last vertical board has to be ripped to the same taper and it laps both the left & right sides comming up
    Mike Smith   Rhode Island : Design / Build / Repair / Restore
