Making a Pair of Board & Batten Doors
| Posted in Construction Techniques on June 1, 2002 07:56am
I’ve been trying to do some fact-finding on how best to make this large pair of doors. Each leaf is 39″W x 89″H x 2 1/2″ – 3″ thick. The tops are curved – don’t know how post a drawing. I’m getting different opinions, of course. I’m stuck. Any thoughts on preferred wood species would also be appreciated.
1. Single layer of T&G boards, glued, with threaded tension rod top and bottom.
2. Single layer of T&G boards, no glue.
3. Double layer of T&G boards nailed together, no glue, with joints offset.
These are outswing doors hinged with a pair of big strap hinges on the exterior.
Gerry in Louisbourg
Note to Newf: Are you interested in making these doors?
  1. Newf | Jun 02, 2002 09:42pm | #1
    Hi Gerry!
    Sure! ...Like to 1700's standards? I made bread boxes for the fortress in the 70's. For Anne MacNeil's Ex, Greg.
    Plywood out?...<G>...
    Lisa Long directed me here from QT. Too many trolls on BT!!!
    [email protected]
    Peace
    Newf                                 Cape Breton, Nova Scotia
    Carpenter, woodworker, gardener, Can't sew or cook
  2. OneofmanyBobs | Jun 02, 2002 10:25pm | #2
    Single layer T&G. Battens on both sides. Do not glue.
    Tension rod or diagonal batten. Cedar holds up pretty well.
    Tension rod on inside is nice. Adjustable without looking tacky.
    3 inches is awful thick. Why? They'll weigh a ton.
    1. Snort | Jun 03, 2002 01:31am | #3
      If these are exterior doors and 2 1/2"-3" thick, why not a ply core sandwiched 'tween 2 layers of T&G? Would eliminate the tensioning rods, and stop a bunch of air infiltration. Whichever way you go, use the straightest (no reaction stuff) wood you can find...the thicker it is, the more it can warp...
      1. gblalonde | Jun 03, 2002 06:14pm | #4
        Thanks for the input.
        Here's link to a picture showing the building. Although the front doors we are replacing are too dark to see.
        http://fortress.uccb.ns.ca/tourism/playhous.jpg
Outdoor Lighting
