making dowels / resawing
dlb01 | Posted in General Discussion on January 3, 2009 05:53am
I recently acquired some mahogany, unfortunately it was full of screws.  I had to use a ‘screw extractor’ to get them out, now it’s full of 3/8″ holes.  I’d like to plug them with dowels but do not own a lathe – can I use a 3/8 round over bit in my router table to round over some stock fill the holes.  Plugs are tapered so I don’t want to use them the wood is 2 by and I’d like to have it resawn into 1 by to make cabinets.  Should I have it resawn before filling the holes?
  1. oldusty | Jan 03, 2009 06:33pm | #1
    Yes , resaw before filling any defects to avoid the plugs tearing out .
        If you turned dowels on the lathe seems you would have end grain showing on the face of the boards .
           After the boards are resawn you could use a plug cutter / maker on the drill press and fill each hole with matching face grain plugs , they are not tapered plugs .The plug cutters come in a set of 3 sizes usually .
                regards          dusty
      dlb01 | Jan 03, 2009 07:18pm | #2
      Thank you
  2. nikkiwood | Jan 03, 2009 07:31pm | #3
    Lie-Nielsen makes a heavy metal plate that you can use to make your own dowels in the standard sizes.
    Cut square stock to rough size, pound piece through hole on plate to make a uniformed sized dowel.
    I've got one, and it works fine -- I use it for making dowels in wood species that are not commonly available in dowel stock.
    $50
    http://www.lie-nielsen.com/catalog.php?sku=DP
    "It is what we learn after we think we know it all, that counts."
    John Wooden 1910-
    1. oldusty | Jan 03, 2009 07:46pm | #4
      Hi nikki ,
               Long time since I've seen your posts , where you been ?
                 Glad your back my friend
                                  dusty , boxmaker
  3. frenchy | Jan 03, 2009 09:10pm | #5
    Use plug cutters.  really simple and very fast! grain orientation is the correct way.  works fastest on a drill press but you can use a hand drill as well! I plug cutter is a few bucks at Home depot and can cut thousands of plugs
    Dinosaur | Jan 03, 2009 09:16pm | #6
    Lee Valley makes sets of tapered plug cutters which work several orders of magnitude better than standard plug cutters.
    The 3/8" size is listed at $16.90 (Canadian) on their website.
    If you match and orient the grain carefully when you insert a tapered plug, the plug just plain disappears after you trim it flush and sand the stock. No tell-tale 'ring' at all. Awesome.
    Dinosaur
    foolish men call Justice....
