Makita Table Saw
| Posted in Tools for Home Building on December 22, 2004 05:16am
I have the 10″ MAKITA TABLE SAW (as well as an 8″).  The dang track for the mitre is a really funky size, and the gauge itself is just junky.  Do you know of any aftermarket one that fits (the Incra doesn’t – even the V27 which they tout as fitting ANY, and (as far as I can tell Woodhaven doesn’t either.
Thanks much.
  1. billyg | Dec 22, 2004 06:07am | #1
    I have the same problem -- I love the Makita saw (with the Rousseau table) but I hate the miter slot.  But it doesn't make sense to use the tabel saw for crosscutting when you have a SCMS.  It could be useful for other cuts though.
    Billy
    1. jrnbj | Dec 22, 2004 07:43am | #2
      Got the same setup...love it, light & portable, but not really made for mitre guage work...though I did make up a crosscut sled....2 little runners almost as good as one real one....
    2. t1hardy | Dec 22, 2004 11:42am | #3
      an scms I have, but it is a pain to do wider stock
  2. JerBear | Dec 22, 2004 03:22pm | #4
    I too have the same setup, the Makita saw with the Russeau tables, a great combo.    If you want a miter slide, (I lost mine years ago),  I would just make one.  Use steel stock or thicker aluminum stock and mill it down.  You could make a pivot arm out of hardwood that would probably work great.  I made a sled for mine that cross cuts up to 20", you could do the same  and then also make a sled that cuts miters.
    1. t1hardy | Dec 22, 2004 07:12pm | #5
      does anyone suppose there would be a reasonable market for such a gauge - using (for instance) a Woodhaven miter gauge ??
