Mantel surround clearance
Kungur | Posted in General Discussion on May 5, 2009 03:58am
I have a job coming up for a mantel surround. The exsisting fireplace has a mantel and the bottom part of the molding is 9″ from the firebox opening.
So my question is what dimension can I use for the side/legs? 9″? The plan is to thinset a tile over the exsisting brick on the verticals and the horizontal.
  1. Dave45 | May 05, 2009 04:13pm | #1
    AFIK, code wants 12" between the edges of the firebox and any combustible material.
    1. Piffin | May 05, 2009 11:39pm | #4
      12" above, but 6-8" at sides, depending on jurisdiction.
      1. Dave45 | May 05, 2009 11:54pm | #5
        I'm pretty sure that it's 12" all around in this area. I'm also pretty sure that this one is pretty high in the long list of ignored code requirements.I made a mantel for a customer in January and included installation in the bid. When I was telling the customer about the 12" requirement and what I would need to do to meet it, he began asking very detailed questions about how I planned to mount it. He then announced that he wanted to save a few bucks and install it himself. Why do I suspect that the mantel isn't 12" away from the firebox? - lol
  2. oops | May 05, 2009 06:38pm | #2
    International Residential Code (2003)
    R1003.12 Mantel and trim. Woodwork or other combustible materials shall not be placed within 6 inches of a fireplace opening. Combustible material within 12 inches of the fireplace opening shall not project more 1/8 inch for each 1-inch distance from such opening.
    As I read it.  At 6" from the opening, you could have, say a piece of molding/trim 3/4" thick. that could increase in thickness at a rate of 1/8"/ft. until you reach 12 inches from the opening. At that point the trim could be 1-1/2" thick. Twelve inches and beyond you can go wild.
    Hope this is what you needed. Good Luck
  3. Piffin | May 05, 2009 11:31pm | #3
    so are you building a new mantle and surround, or just tiling the brick masonry face?
    Existing is grandfathered.
    New, means 12" clear above, plus an eighth for every inch of projection
  • A Postwar Comeback
  • Natural Simplicity
  • A Grand Rescue on the Coast
