MANTLE FINISH
deskguy | Posted in General Discussion on October 23, 2009 11:47am
hava 2x 12 hickory mantle going over a gas fireplace.  What clear coat finish would you put on it?  does it even matter?  I am using the coded set backs ( or ups) but I imagine it’ll still get warm.
thanks in advance
    MrSQL | Oct 23, 2009 11:54pm | #1
    I'd say go with a water based poly because if you ever want to re-finish in place it's no big deal in term of fumes.
    I used an oil finish on my cherry mantle.
    1. deskguy | Oct 24, 2009 10:13am | #4
      thanks for the reply.  hope I don't have to refinish anytime soon.  have never heard of any concern in regards to finish over a fireplace, but it never hurts to ask.  Going to do the rub on finish, and hopefully mount it on sunday.
      thank you for your reply
    2. deskguy | Oct 24, 2009 10:19am | #5
      second question upon rereading your post.  what should a decent 3 coat oilbased finish last for?
      I mean, If I have to refinish.  How soon, and how long will I have to put the family in a hotel???? :)
    PeterJ | Oct 24, 2009 12:28am | #2
    Don't know your finishing skill, but I sometimes reccommend Minwax Wipe-On Poly to clients. Takes many coats, but is really easy to apply and hard to get bad results if you're patient and do some careful sanding between coats.
    It's oil base, so it stinks. Also it has an amber cast like most oil base finishes, imparts a nice tone to many woods. If you want water clear, water borne is you best bet.
    1. deskguy | Oct 24, 2009 10:10am | #3
      sounds like the water finish is the way to go since it will never catch on fire.....  :)  I picked up some rub on on the way home, will lay it on tomorrow, and sand between coats.  Has a chisled face so hope it doesn't need a heavy sanding.  Was thinking of a water base, but want a slightly more "yellowed" look.
      Just wanted to make sure there was no concern of finishes over heat.
      Thanks again
        PeterJ | Oct 24, 2009 04:46pm | #6
        Try this or close. Sand raw wood to 180 or so
        2 coats poly
        light sand 220 to shave nubs and flatten goobers
        2- 5 more coats, medium scotchbrite between, see how that looks to you. If you want a thicker buildup just keep going with that regimen. The patience comes because of dry time between coats, at least overnight and a day or more wouldn't hurt.
FHB Podcast Segment: Roofing on Commercial vs. Residential Buildings
In certain scenarios, flat roofs make more sense than pitched roofs (and vice versa).
  • A Postwar Comeback
