Masonite for concrete forms
glenburn | Posted in Construction Techniques on July 7, 2002 07:55am
I’ve got a project that requires a 5″ concrete slab with multiple, compound curves.  Normally I would use 2×6’s, cut a few kerfs and bend the forms where I need to.  If I do that on this job, I’ll be cutting kerfs for 2 days – not an option.
I’ve used 5/8″ plywood in the past for gentle curves, but there are some tight ones on this project.  The next thought is to use Masonite.
My question is what thickness of Masonite would you recommend???  I’ve seen it used before, but I’ve never had the need.  Specifically, I’ve seen 1/2″ Masonite used to pour a 4″ slab, but this pour is going to be 5″, and I have some skepticism about using 1/2″ Masonite to form up for a 5″ thick pour.
Thanks.
  1. BKCBUILDER | Jul 07, 2002 08:19pm | #1
     Hardboard siding, it comes 1/2" x 10" is primed both sides, and comes in 16" lengths. Tale it and rip it into 2-5" widths.
    1. FastEddie1 | Jul 07, 2002 10:09pm | #2
      My local plywood shop (not a regular lumber yard) stocks bendable plywood in 4x8 sheets.
      1. BKCBUILDER | Jul 08, 2002 12:59am | #3
         We find the problem with 8" lengths is that a joint always falls in the bend on compounds, that's why we opt for the 16' strips of siding........to each his own.
      CloudHidden | Jul 08, 2002 01:38am | #4
      I second the hardboard. Used it for curved forming on an 8" slab and it worked great. That was suggested by the finishers. They use masonite (I think) on lesser curves, but use hardboard on the tighter curves.
  2. JAMES70114 | Jul 08, 2002 06:04am | #5
    I put my vote for curve-a-board. It is the brand name for a bendable plywood. It is two to three times more expensive per sheet, but hey, tell the architect that!
    scares me, and I'm fearless
