mastic or construction adhesive or other
jikkk | Posted in General Discussion on October 23, 2006 06:27am
I am using 1×2 mosiac split face travetine tiles on a 8’x8′ wall. The stone is tight fit and does not get grouted.The mesh backing contains alot of glue so their is little contact between the adhesive I use and the actual stone.  I am looking for ideas on the best adhesive to use. It is a dry area and the wall is unpainted drywall.Thinking about tile mastic? Any ideas? I need something with low slag, something with good inital tack?
Thanks for any input! Jim
  1. woodroe | Oct 25, 2006 02:07am | #1
    Prime the wall first. I guess I'd use a tile mastic trowelled on the wall. Probably a 3/16th inch v-notch trowel. It would probably worth a call to your local tile shop and ask for their recommendation, but without seeing what you're putting up I don't think construction adhesive wold be on my list of possible choices.
  2. andybuildz | Oct 25, 2006 04:49am | #2
    mastic is perfect for that application.
    Creation arises, is sustained for awhile, and then things change. That’s the dance.
    http://www.ramdass.com
  3. FastEddie | Oct 25, 2006 05:06am | #3
    Construction adhesive would be a bad choice.
    Mapei makes a thinset called UltraContact or similar.  It has a lot of initial tack.
