Matching old Bruce hardwood flooring
| Posted in General Discussion on February 13, 2000 07:44am
I am installing 122sf of new 3/8″ prefinished hardwood flooring next to existing 3/8″ x 4 1/2″ prefinished. Each piece varies in size and has different size strips within, although most are 2 1/2″ and 2″ within the 4 1/2″. I believe the existing is Bruce as it has the 1″ ribs on the back.
I have looked at new Bruce and found 3″ wide butterscotch, with adhesive strips not on original, to be close but no ciger. Can anyone recommend, if Bruce did come in 4 1/2″ wide, where I can obtain a good match.
  1. Jr._Brady | Feb 13, 2000 07:44pm | #1
    I am installing 122sf of new 3/8" prefinished hardwood flooring next to existing 3/8" x 4 1/2" prefinished. Each piece varies in size and has different size strips within, although most are 2 1/2" and 2" within the 4 1/2". I believe the existing is Bruce as it has the 1" ribs on the back.
    I have looked at new Bruce and found 3" wide butterscotch, with adhesive strips not on original, to be close but no ciger. Can anyone recommend, if Bruce did come in 4 1/2" wide, where I can obtain a good match.
  2. Guest_ | Feb 13, 2000 07:44pm | #2
    Tom:
    The existing sounds like the old Hartco. Chances are you won't get a good color match due to the aging process.
    Good Luck
Two Ways to Test Windows
  • The New Old Colonial
