mc cable
| Posted in General Discussion on December 20, 1998 02:46am
I use my DeWalt 12v cordless saw with a carbide blade to cut that stuff (slow feed rate and wear the goggles – I also shut my eyes). The DW cordless also cuts my conduit, power strut, rigid and triplex cable. Works quite well.
If you are really into it, Panasonic makes a cordless saw set up for this kind of thing.
j wells
  1. John_Wells | Dec 20, 1998 02:46pm | #1
    I use my DeWalt 12v cordless saw with a carbide blade to cut that stuff (slow feed rate and wear the goggles - I also shut my eyes). The DW cordless also cuts my conduit, power strut, rigid and triplex cable. Works quite well.
    j wells
  2. Guest_ | Dec 21, 1998 03:20am | #2
    Bear, Greenlee tool co. makes a roto cutter that fits in your palm.You just apply a little pressure and crank the handle a couple of times.It cuts clean and fast. I prefer to just bend the M/C back onto itself untill the armor opens,counter torque with my hands the spiral of the armor and use a pair of Klein M/C cutters to snip the armor.It sounds like a lot but it only takes about 5 secs. a cut. Sparky
  3. Sparky_II | Dec 21, 1998 03:35am | #3
    I just turn the m/c a full half-turn and bite it in two. If you have dentures, you might want to get yourself one of those roto-tools from the supply house. They're only about 30.00.
  4. Guest_ | Dec 21, 1998 03:36am | #4
    Does anyone know any tricks for cutting mc cable or flexible
    metallic conduit w/12-2 w/ground? I have a bit of this to run
    and it's slow slow slow.
    Thanks in advance
