MDF for exterior trim???
thebozer | Posted in General Discussion on May 2, 2005 11:53am
WHat’s the consensus on using MDF for exterior trim. i plan on backpriming everything.
  1. DougU | May 03, 2005 12:10am | #1
    they make an exterior MDF, I believe its called Medex, there are other brand names as well.
  2. gdavis62 | May 03, 2005 12:24am | #2
    There is no real exterior rated MDF.  Medex has some water resistance, but not enough for any exterior trim work.
    This, from SierraPine's website (they make Medex):
    Medex is an SCS certified, no-added formaldehyde, moisture resistant MDF panel engineered for interior high moisture areas.
    That's my accent on the word "interior."
    Why not cedar or redwood?  Why not Azek or Primetrim?
    Edited 5/2/2005 5:31 pm ET by Gene Davis
  3. reinvent | May 03, 2005 01:01am | #3
    If you need sheet stock to cut up into x terior trim then you should use MDO (Medium Density Overlay) its a plywood with a paper facing specificly made for x terior use. Sometimes used for street sighns. Do not use MDF or MDX they are not rated for your needs.
    1. thebozer | May 03, 2005 03:34am | #4
      excellent info. thanks very much.
      1. nikkiwood | May 03, 2005 03:48am | #5
        I will just echo what reinvent said. Avoid any MDF product; if you need sheet stock, use MDO -- but you will have to contend with the exposed veneer edges."I would never die for my beliefs because I might be wrong."
        -- Bertrand Russell
    Dinosaur | May 03, 2005 04:51am | #6
    No.
    Dinosaur
  5. Mitremike | May 03, 2005 06:46am | #7
    Try Mira-tec Exterior grade product--if it isn't Mdf treated it is real close- used 5/4 of the stuff around my windows 2 years ago and it hasn't opened the joints and looks like I painted it yester.
    cut like mdf and routs too--it is made for outdoors with some sort of epox binder . In any case I have had excellent results with it and it may be worth a search on the web if someone around you carrys it.
    Mike" I reject your reality and substitute my own"
    Adam Savage---Mythbusters
    I found their site it is Miratectrim.com---As suntoad says it is smooth on one side ( my use) and embossed on the other.
    It comes preprimed on the face and after I milled it before install I hit the other edges and screwed it around the windows--It is really hard stuff so I didn't have much luck with the nails so I screwed and puttied the holes with auto bondo and I bet ya a buck you can't find them. :-)
    Edited 5/4/2005 12:04 am ET by mitremike
    1. suntoad | May 03, 2005 03:12pm | #8
      I've used MiraTech. I replaced all the fascia boards on the house I'm renovating w/ their 5/4 x 8" stock. It comes pre-primed and stamped with a "cedar" grain. Paints up real nice and looks great. Can't vouch for longevity yet, it's only been up for about 7 months. So far so good (survived two hurricanes).
      1. Mitremike | May 04, 2005 07:08am | #9
        Around here Mn. it has 2 summer and 2 winters under its belt and it wouldn't look this good now if it was true wood. I have more plans for the back of the house and it is on my list of must have materials despite it's appitite for dulling blades.Hurricanes huh? Florida or maybe Miss.? I would guess that if it can hold up to that and our winters that would be a winner in my book.Mike" I reject your reality and substitute my own"
