Medicine Cabinet Installation
JourneymanCarpenterT | Posted in Construction Techniques on August 13, 2009 10:28am
Perhaps this seems like a rather simple question, but I always find some of the responses to these types of questions fascinating.  Whether it’s an unusual tool to measure casing, a different way to cope crown, or a debate about the best way to cut a scribed cabinet, I always seem to get something out of it.<!—-><!—-> <!—->
I haven’t been posting for a little while, but as some of you already know, I’ve been working on lists of tools for particular jobs so that I don’t forget anything.  So, here I go again:<!—-><!—->
I’m going to lump hand and power tools together in this one.  What are all of the tools you bring with you to install a simple bathroom medicine/wall cabinet? <!—-><!—->
–T
  1. DanH | Aug 13, 2009 11:47pm | #1
    Something like the old Boy Scout smoke shifter, only for pipes, to move the vent pipe out of the way.
    As I stood before the gates I realized that I never want to be as certain about anything as were the people who built this place. --Rabbi Sheila Peltz, on her visit to Auschwitz
  2. webby | Aug 14, 2009 01:27am | #2
    Some Mighty Putty! Just stick the thing to the wall. It'l work 'cause the Mighty Putty is rated for 300 pounds. ";^)
    Ok, and maybe a level.
    Webby
    Edited 8/13/2009 6:29 pm ET by webby
    1. rez | Aug 14, 2009 05:33am | #8
      The old skilled carpenters from way back when could just eyeball it level.
      be on the level
      1. DanH | Aug 14, 2009 05:35am | #9
        They got away with that because of the 20-degree slope of the floor.
  3. Shep | Aug 14, 2009 02:51am | #3
    OK, first I need to know if its a recessed or surface mounted cabinet.
    New work, or replacing an existing cabinet.
    Fpor a surface mounted cabinet, all I'd need is an impact driver and a level and some screws. Unless its got a light built in. Then I'd need some electrical tools.
    For installing a new recessed cabinet in an existing wall, I'd need just about every tool in my van. Circ saw, MM, recip saw, drywall saw...
    And probably a few I'd forget to bring.
    1. DanH | Aug 14, 2009 03:03am | #4
      Yep, and a lot has to do with what the wall surface is, and whether there's been a cabinet before.As I pointed out, very often there is a vent pipe in the wall directly above the lav -- right where you want to put the cabinet. Sometimes you can push it back in the wall a bit (especially if it's a 6" soil wall), sometimes you can cut he pipe and reroute it around the cabinet (but you'll have a lot of wall repair to do), sometimes you just have to space out the cabinet somehow due to the reduced depth.
      1. Shep | Aug 14, 2009 05:27am | #7
        It seems like the simple questions can get complicated pretty quickly in remodeling. LOL
  4. RedfordHenry | Aug 14, 2009 04:58am | #5
    I'd bring them all, just in case.
    1. DanH | Aug 14, 2009 05:01am | #6
      Actually, a better idea is to remove the wall and take it to your shop.
A Practical Perfect Wall
  • The New Old Colonial
