metal cutting circular saw
craigf | Posted in Construction Techniques on June 30, 2009 11:55am
I’m sure this has been discussed before, but Breaktime’s search function didn’t return anything.
I’ve got to cut around 80 sheets of corregated 29 ga. metal siding sheets to length. I saw a Kawasaki metal cutting circular saw at the lumberyard and grabbed it.
My plan is to stack some sheets together and cut them.
Has anybody done anything like this?
How many sheets will it cut at a time ?
What else can this saw be used for and how thick of metal will it cut?
  1. catfish | Jul 01, 2009 12:32am | #1
    Don't do it, it will throw little chips and burn the coating off the panels.  (If painted)  Then it will rust whereever they hit.  Use snips.
    1. craigf | Jul 01, 2009 04:02am | #6
      Thanks for bringing up something to watch out for. This saw has an enclosed housing which is supposed to catch the chips. I'll have to check it out.
      1. catfish | Jul 01, 2009 03:04pm | #31
        If you have to do it, cut them on the ground, about 10 pieces at a time.  Turn them upside down, and hide the cut under the ridge.  Leave the factory side as your eave.
        also, drill them all at once and the screws will line up perfectly.
        1. Boats234 | Jul 01, 2009 04:54pm | #37
          I agree with you on the PITA cuttings left behind from a saw cut.
          The only time I'll yse a saw now is for an exposed valley where I need a sharp line... can't do it with shears or a nibbler.
          I used to predrill all my sheets but now I have mixed feelings for that.
          My supplier carries these new screws that start thru the panel so easy http://www.sealtite.com/wb-zxl.htm
          So a lot of other factors come to play before I predrill.
          Whats the slope?? Can I go back with a string line?? Is it highly visable if I eyeball it??
          But if your running a straight gable and everything is uniform, predrilling is the way to go.
  2. rez | Jul 01, 2009 12:52am | #2
    Buy extra blades.
    1. craigf | Jul 01, 2009 04:06am | #7
      Yeah, it always seems like I'm always one blade short of finishing. Do these carbide metal blades get chewed up pretty quick?
      1. rez | Jul 01, 2009 04:39am | #16
        Well, since you bought the saw looks like you'll at least be attempting the deal.
        No expert here but played the cut man this past winter on a slew of sheets and it can be done without a whole lotta hassle but can have it's moments.
        Protecting the blade by slow even paced cuts seems the best plan of attack
        as getting hostile or pushing the saw too hard can create probs that end up chipping a tooth
        which seems to immediately influence the cutting potential.
        That last inch in a cut can be problematic if not attentive as it wants to bind if not supported correctly.
        Have two blades in reserve when you start just to cover yerself.
        Edited 6/30/2009 9:41 pm ET by rez
        1. craigf | Jul 01, 2009 04:51am | #20
          Thanks for the advice Rez.
          IMERC | Jul 01, 2009 11:53am | #29
          he's gonna tke the saw back and get the shear...
          WOW!!! What a Ride!
    IMERC | Jul 01, 2009 12:58am | #3
    rent a shear...
    WOW!!! What a Ride!
    1. rez | Jul 01, 2009 01:03am | #4
      Ya, 80s a bunch and those blades aren't cheap.
    2. craigf | Jul 01, 2009 04:09am | #9
      That's maybe what I end up doing or buying some of those Malco shears that fit on a drill. Probably spending more time dreading cutting each sheet than actually doing it.
        IMERC | Jul 01, 2009 11:52am | #28
        this kinda shear....
        http://www.acra.com.au/NewProduct.aspx?Id=63
        Corrugated Iron Hand Shears
        Australian made, and manufactured, these simple machines allow the operator to cut back, or trim sheets for industries such as Domestic Roofing, Bull Nosing, Water Tanks, Pergolas, Sheds and Cubbies. Compact and light enough to take onto site to trim sheets quickly and cleanly giving a much better edge than a pair of tin snips. Also available in profiles to cut Bluescope Lysaght Trimdek, Smartascreen and Multiclad, Stramit “K” Panel, Woodroffe Lo-Rib & Gramline Fence Profile
        WOW!!! What a Ride!
        1. craigf | Jul 01, 2009 03:29pm | #34
          AAAAHA! Thats the ticket! However, I live where I doubt there are any available to rent.
            IMERC | Jul 01, 2009 03:33pm | #35
            how close are ya to Denver or the Springs???
            buy instead...
            WOW!!! What a Ride!
            Edited 7/1/2009 8:34 am by IMERC
            IMERC | Jul 01, 2009 04:05pm | #36
            so now ya explore the website listed and find a dealer...
            buy the shear and then sell when yur done...
            or keep it...
            WOW!!! What a Ride!
          3. craigf | Jul 02, 2009 03:45am | #39
            Hmmm....I'm about 3 hrs away. I'll check out the website and think about it.
            IMERC | Jul 02, 2009 03:55am | #40
            check in Limon....
            WOW!!! What a Ride!
            IMERC | Jul 02, 2009 03:55am | #41
            Big R may still carry them....
            WOW!!! What a Ride!
          6. craigf | Jul 02, 2009 03:58am | #43
            Hey thanks, that wouldn't be a bad drive at all.
          7. User avater
            IMERC | Jul 02, 2009 04:11am | #45
            Big R is in Falcon on 24...
            WOW!!! What a Ride!
          8. craigf | Jul 02, 2009 04:55am | #48
            I'll give em a call
          9. craigf | Jul 02, 2009 04:06am | #44
            Do you work in E. Colo. much? I helped a buddy on a job in Last Chance. We'd eat at a good cafe in downtown Limon. If your through sometime and our schedule lines up, I'll buy.
          10. User avater
            IMERC | Jul 02, 2009 04:12am | #46
            No... that'd be a jaunt for me...
            I'm pretty far out into the mountains...
            WOW!!! What a Ride!
  4. DanH | Jul 01, 2009 03:11am | #5
    I've never used the metal-cutting circ saw blades (look a bit like ordinary carbide wood blades), but I've seen them used.
    It's not exactly like cutting butter. The blades buck quite a bit, and I'd be very leery of trying to cut through more than one sheet at a time, or of cutting something that wasn't fairly well secured.
    I have seen the blades (Panasonic, not Hitachi) used to cut fairly thick stuff such as Unistrut -- don't know what gauge that would be.
    As I stood before the gates I realized that I never want to be as certain about anything as were the people who built this place. --Rabbi Sheila Peltz, on her visit to Auschwitz
    1. craigf | Jul 01, 2009 04:12am | #10
      Good news on being able to cut unistrut etc. Maybe I can use the saw for other things.
  5. Marson | Jul 01, 2009 04:07am | #8
    I've used a #### steel cutting blade for cutting steel lap siding with a 7 1/4" circular saw. It cuts without burning. Like butter, really. That's one piece at a time. I'd be leery about stacking too many up--I think heat could get to be a problem.
    I once sided a shed of mine by cutting maybe 10 pieces at once. With a regular carbide skil saw blade. Whoo boy did it melt that blade eventually. I didn't really care about burning though since I could put the cuts under the ridge cap.
    1. craigf | Jul 01, 2009 04:16am | #11
      Thanks Marson. Sounds like heat is going to be the problem.
    Dam_inspector | Jul 01, 2009 04:25am | #12
    What size blades does it use?
    Harbor freight has 7 1/4" metal cutting blades that Ponytl really likes.
    1. craigf | Jul 01, 2009 04:33am | #14
      They are 7 1/4". I'll check out HF. Thanks.
        Dam_inspector | Jul 01, 2009 04:45am | #17
        http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=94642
        1. rez | Jul 01, 2009 04:48am | #18
          Good idear. We were shelling out a whole lot more than that for blades at the time.
            Dam_inspector | Jul 01, 2009 04:51am | #19
            I never used em, but Ponytl says they are the cats meow.
          2. Robrehm | Jul 01, 2009 05:13am | #22
            I"m curious about the blades from harbor freight, I tend to use either the Frued or Morse blades. the quality of the blade makes a difference but if the harbor freight blades are up to snuff I'm interested. I have some 12 gauge floor joist I"m cutting down for a bridge so I will give them a try."this dog may be old but he ain't cold. And he still knows how to bury a bone."
            Lattimore
            http://www.rehmodeling.com
            Dam_inspector | Jul 01, 2009 05:20am | #24
            Amy stories on these blades? Work well? What do you cut with them?
          4. ponytl | Jul 02, 2009 04:16am | #47
            i think i should get a commission on the blade i brag about from harbor freight...  i just finished 250 ft of metal fence and didn't even kill one blade  @$16.00  they are still a deal  use to be about $9
            i have a killer makita 7.25 miter/chop saw  i keep one mounted on...  i regually cut 1.25" solid round stock with zero problems
            p:)
        2. craigf | Jul 01, 2009 04:59am | #21
          Glad you posted the link. I was looking and missing them.What does ponytl cut with his?
            Dam_inspector | Jul 01, 2009 05:19am | #23
            He cuts beams and heavy steel with his.
          2. craigf | Jul 01, 2009 03:23pm | #32
            Cool
    2. DanH | Jul 01, 2009 06:08am | #25
      The blades I've seen are 5 1/2 or so.
  7. User avater
    bluejae | Jul 01, 2009 04:26am | #13
    Ive done a bit of metal framing with a 7 1/4 circ blade by tenryu, cuts 2 3/8 thick wall steel poles almost like butter . I dont think stacking 3 or 4 sheets of corrugated together would be a problem. Buy a piece of the wiggle mould to help support the cut.
    Edited 6/30/2009 9:34 pm ET by bluejae
    1. craigf | Jul 01, 2009 04:36am | #15
      I'll have to sheepishly admit my ignorance.What's a wall pole and wiggle mould?
        bluejae | Jul 01, 2009 08:45am | #27
        Sorry, I worded that wrong. Its just a heavy gague steel fence pole approx 1/8 inch thick,like the kind you see supporting a chain link fence. Wiggle mould is a piece of wood milled with curves to match that of the corrugated roofing, used to help keep the roofings shape when fastened down. If a home center or lumberyard carries corrugated roofing they should have wiggle mould nearby. You can get a few pieces to help support the sheets at the cutline.
        Edited 7/1/2009 1:47 am ET by bluejae
  8. Waters | Jul 01, 2009 06:15am | #26
    I had to cut a bunch of crappy galv delta rib roofing a while back and bought a freud metal cutting blade for my wormdrive.
    It's a 'triple chip' design.  If you look at the teeth they cut left, right and straight on.
    I stacked and cut them all like I wanted to and it worked great.  Not too hot and chips out the back of the saw just like normal.
    Then you can spray prime the ends if you want--all stacked there neatly.
    1. craigf | Jul 01, 2009 03:24pm | #33
      Good to know. Thanks
  9. TommyC | Jul 01, 2009 12:39pm | #30
    Craig,
    Rent the shear.
    Save your ears.
    Regards,
    Thomas
  10. Dave45 | Jul 01, 2009 04:55pm | #38
    Several years ago, I cut the corregated roofing for a barn using a 7.25" circ saw with the blade in backwards. It was noisy, but it worked fine.
    1. craigf | Jul 02, 2009 03:57am | #42
      I've done that before. Even with earplugs the sound is terrible. I cut a scrap pc. with this saw and blade and the speed of the saw seem to cut pretty good. I can see the metal needs to be well supported though.
Fast, Accurate Wall Framing
  • Smarter Stop Block
  • Square Walls Solo
  • Deck-Board Pry Bar
  • Insulation Scrap Dispenser
