Metal frame door
user-5487038 | Posted in Construction Techniques on January 17, 2017 11:30am
CMU 1962 house. All interior/exterior doors are metal jamb with non movable hinges.
Couple of questions.
install metal/fiberglass door on entry. Does anyone sell exterior door blank that allows site install hinge and lock set.
can you change swing on interior frames for wood door.
thanks
  1. calvin | Jan 17, 2017 02:24pm | #1
    User
    Yes to both questions, but....
    Metal clad or fiberglass clad slabs can be purchased through good local lumberyard a, can't say about the box stores that drive them out of business.  Call your yard and talk with them.  Their suppliers are usually the ones that hang and prep those slabs to jambs.  There are size constraints involved with the usual slabs they are given.  Know your jamb opening to the 1/8 and make the call.
    You can recut hinge mortises on existing in place jambs, with router or chisel.  A good carpenter should have no problem.  One thing to consider if using the former door hung in that opening is that the latch edge most likely is beveled.  Where it swung easily into the original jamb it may now bind.  So, you might have to remove a bit of that old (now too wide) bevel.  When closed it will create a wide space between jamb and door than b/4.
    1. DanH | Jan 17, 2017 03:22pm | #2
      I don't think you can set new hinges into a metal jamb with a chisel and router.
      1. calvin | Jan 17, 2017 04:14pm | #3
        Whooops
        get a torch.....
    BossHog | Jan 22, 2017 09:44am | #4
    I work at a "real"
    I work at a "real" lumberyard.  I have ordered slabs before just exactly for the situation you describe.
    Called the supplier, explained the situation.  Got their exact door slab size and compared it to the existing metal frame.  Ordered the slab with no hinge prep and no lock bore.
    Took some effort, but was not a big deal.
