Hello, I’m thinking of building a metal gate with vertical wood panels based on the attached sketch. This is my first time building one. I’m have a few questions. Should I use 14g or 16g posts? How deep should I dig the post and how much cement should I use? I live where there is not freezing. Left post will be attached to the house. Should I use two or four hinges on the door. Do you have recommended hinges? Should I use 14g on the hinge side of the door? I want to use a regular door handle and dead bolt on the gate. Thanks.
Listeners write in about shower panels and cordless tools and ask questions about old wiring, air leaks, and gutter covers.
You should use at least .120” posts. 14 or16 gauge are basically sheet metal. If you’re using 2” posts set a sleeve of galvanized metal big enough to fit the post 2.5’ in the ground. If your soil is solid a post hole size hole with concrete should be fine. Slide the posts all the way into the sleeve. Caulk or weld the post to the sleeve. I don’t like welding galvanized material and I was applying a patina that didn’t require it on a recent project. I used a 2 weld on barrel hinges without any leaves. They turn on a single ball bearing and have a zerk for grease
