Metal granules (possibly slag) under my slab!?!?
x_navyfc | Posted in General Discussion on August 6, 2021 02:14pm
I’m about 90 percent sure that instead of gravel, there are fine metallic particles under my cement slab downstairs.
House was built in 1968. I busted up a cement porch outside my back door and found these particles inbetween the slab and the dirt. They stick to a magnet, look rust colored, and are about the size of a grain of rice or smaller.
I also seen them when digging up my foundation along with the occasional black shiny rock that appears to be iron ore slag from pictures on the interwebs. The layer of these granules are probably 4-6” thick and sucked to dig through.
My slab is also cracked in heaved in most of my downstairs, so I’ll be able to confirm the slag is used there too when I bust it up.
Why did they use it instead of gravel, and does it need to be replaced with gravel?
Could that have been a factor in my slab heaving? I did find plugged up clay draintile as well.
Thanks.
    tfarwell | Aug 09, 2021 08:29pm | #1
    I know you can buy ground mill slag for driveways. I bought some for mine - compacts down tight and weeds don't like to grow in it. So for that application it worked well for me, and the stuff was really cheap - I paid a small fee and the cost of delivery and dumping.
    http://www.harscocrushedrock.com/materials/steel-slag-construction-projects.php
    I don't know that it would be good for structural fill, as it seems to break down into finer material over time.
    1. x_navyfc | Aug 10, 2021 06:35am | #2
      That’s interesting.
      I wonder if the builder did something similar here and it just broke down into the finer material that I am seeing now…
      This house has been full of weird materials and methods so I guess nothing surprises me anymore.
      Was the slag cheaper than stone? I have to think the only reason they would have used it in ‘68 was if it was less expensive than gravel at the time.
