Metal Roof
oldschool | Posted in General Discussion on September 9, 2004 04:41am
I have had a metal roof on my cabin for 9 years.  The roof is not a standing seam.  The screws that hold it in place are exposed to the weather.  Every spring, after the snow is gone, I find the last row of screws closest to the eave, backed out or missing.  I have tried to silicon them in place with no luck.  Has anyone else experienced this problem and found a solution.
    Dinosaur | Sep 09, 2004 05:25am | #1
    I would guess you have a pretty good-sized ice dam built up on that eave by spring, and it's the ice when it finally lets go and slides off  that's damn near ripping the screws out of the roof deck.
    Install an ice fence on the slope of the roof where this is a problem; frequently this is the south facing side, as a lot of direct sunlight can cause this sort of ice buildup even in the absence of escaping interior heat. The ice fence prevents the dam from sliding off the roof until it melts down small enough that it won't do any damage.
    Dinosaur
    DaveMason2 | Sep 09, 2004 09:36am | #2
    You might try Lexal instead of silicon. It works alot better on metal roofing.
    Dave
    1. oldschool | Sep 11, 2004 08:02pm | #3
      Thanks for the suggestion Dave.  What is lexal?
        EricPaulson | Sep 11, 2004 08:20pm | #4
        think it might be LEXEL, not sure though, good stuff, a roofing or siding place should carry it.
        EricEvery once in a while, something goes right!
      teasea | Sep 13, 2004 08:13am | #8
      what part of ak are you at dave?
  3. Grott | Sep 11, 2004 08:45pm | #5
    Oldschool,
    How solid is the rood deck or purlin system at the eave?
    I have used pan head screws with neopreen washers ond or butal caulking to seal them down in situations where low profile was important(valleys and eaves with ice problems)
    Snow Jax are also a good product to use, they screw to the roof and hold snow/ice in place while it melts.
    Good luck,
    Garett
    1. oldschool | Sep 11, 2004 08:58pm | #6
      All systems are good.  The roof deck is OSB and I thought that might be the problem.  However when I screw the fasteners back in they hold very well.  I think the physics of the metal roof expanding and contracting has something to do with the screws backing out.  The pitch is 12/12.  I don't understand why the snow/ice only affects the eave screws.  I will experiment with all of the suggestions that have been posted.
        teasea | Sep 13, 2004 08:08am | #7
        having a 12 12 pitch makes dinosaurs post even more acceptable
Two Ways to Test Windows
  • The New Old Colonial
