Metal Roof Sources -Copper Look
| Posted in General Discussion on June 17, 2004 11:57am
Great site as a resource.  Usually can find what I need without posting, but need some help here.
Designing and building a high end community rec facility and looking for a standing seam metal roof type product that either looks like new copper or an aged/patina copper.  The goal here is a very authentic look while reducing the costs.  They are serving as accents/peaks on various structures within the community and would have a maximum footprint of 4’x4′.
This product will also be in the same area as a slate composite shingle product , any sources here would be welcome also.  I have found some good looking samples with Max and Duraslate.
Most of the manufacturers for the metal product I have found show a very generic, painted looking version of the shiny copper.  Looking for something better.
Or, is there not that big of a difference in cost between the metal panels and the real thing?
Thanks.
TN
  1. draket | Jun 18, 2004 12:26am | #1
    TN
    I have seen a few products, one that changes color depending on from which angle you are looking at it. I'll see if I can't dig up that sample and give you a name. The problem I ran into was these imitations are almost if not as expensive as the real thing (material wise). If you are going to install it yourself I would go with copper. If someone else will install it you might run into the same problem as I have. I think the metal contractors who I had bid the job saw big $$$  when the word copper was used. I know the material is significantly more, and I know one must take much more care in handling the soft material of copper, but the labor cost difference between a galvalume type and copper was ridiculous. I think they know it's a specialty thing, and assume if you want a copper roof, you have money to burn. I'm still searching for a copper guy who will change my theory.
    Fighter
    Northern CA
  2. seeyou | Jun 18, 2004 01:26am | #2
    The last three steel roof jobs I've been asked to bid, I've also turned in a copper bid. All three were within 10%. I'll be doing two of them in copper. Don't know what's up with the 3rd. Steel and copper have both gone up. Steel's gone up more.
    .: If this post is not up to your standards, please lower your standards :.
  3. TN | Jun 18, 2004 10:06pm | #3
    Thanks for the input guys.
    I've been running into similar scenarios here.  Cost between the two are very close, so we'll probably go with the real thing.
    Maybe I should have gone into the copper sheet metal business.
    1. JohnSprung | Jun 18, 2004 11:59pm | #4
      Instead of 16 oz. copper, there's a material they call "tough 12", a 12 oz/sq. ft. copper roofing product.  I haven't seen it, but it should reduce the material cost by about a quarter.  Greencu is the copper expert, perhaps he can comment on "tough 12".
      Also have a look at http://www.copper.org, the Copper Development Association web site.  It's not well organized, but if you poke around long enough, there's lots of information there.
      -- J.S.
      Edited 6/18/2004 5:02 pm ET by JOHN_SPRUNG
      1. seeyou | Jun 19, 2004 01:23pm | #5
        I've never heard of "tough 12". 12 oz copper is pretty flimsy stuff, though. I did look into a product called "SS copper" or something like that. I can't find the website now. It's copper coated stainless steel. Looked promising, but was only available in metric ton rolls which doesn't suit my set up.
Choosing a Paintbrush
  • The New Old Colonial
