I am about to put metal roofing on my house. I have completed the separate carport and shop which only encounter ridges and valleys. On the house I will encounter various vents and stacks. I have shingled around such items muchos but how in the world do you seal metal roofing around such items.
Understand lumens, ceiling brightness, beam spread, tilt, and color options to make a wise choice on a common fixture that can range from $75 to $750 or more.
There is a special flexible stack flashing jack for them.
there are also special silicone flashings for your gas vent pipes.
and there are studor vents you can put in the attic to cut down on plumbing vent penetrations... EliphIno!
