Metal siding-pipes, conduits
craigf | Posted in Construction Techniques on July 14, 2009 08:59am
Installing corrugated metal panel siding. There are pipes and conduits going through the wall which I can’t disconnect.
What’s a clean way to handle this?
  1. DaveRicheson | Jul 14, 2009 09:45pm | #1
    Drill a hole at the pipe/conduite location. Cut siding verticaly or horizontal for the edge of the siding nearest the hole and slide the siding in place. Back up the slit cut with another  piece of siding  long enough to catch the screw/nail patern and buttered with a good polyuertane caulk.
    Not perfect, but you don't have many choices.
    1. craigf | Jul 15, 2009 04:19pm | #3
      Thanks Dave. I was wondering if anyone had any ideas on trimming the slit out.
  2. inD47 | Jul 15, 2009 05:00am | #2
    A match
  3. dovetail97128 | Jul 15, 2009 05:27pm | #4
    If I have the material to work with (meaning some extra) I shingle the wall in . Pretty much the same as working on penetrations on a roof.
    Mark the hole, cut the sheet 3" above the top edge of the hole along with cutting a slot to accommodate the pipe. The make up another sheet with a reverse of the slot and fit it over the pipe and over the lower sheet.
    Leaves just a small area right at the pipe to be caulked.
    1. craigf | Jul 15, 2009 10:47pm | #5
      Great idea! Thanks.
