Traditional lime wash still has tons of useful applications.
more blocking or verticale supports..
WOW!!! What a Ride!
hit the studs and use togglers...
screws fail...
WOW!!! What a Ride!
toggle on a ledger strip.. set the cabs on that..
use a french cleat...
and still toggle the cabs to the walls....
WOW!!! What a Ride!
Toggles, French cleats, & adhesive.
The awful thing is that beauty is mysterious as well as terrible. God and the devil are fighting there, and the battlefield is the heart of man.
- Fyodor Dostoyevski
I would remove sheetrock, install blocking and resheet with plywood behind wall cabinet locations. For base cabinets, togglebolts would do, or same method as for uppers.
Do you know the gauge of the studs? If they are 20s / 18s, 16s then hanging with screws is not a problem. Self-tapping number 8s can be purchased readily. If the studs are 25s, then I would be somewhat more concerned. However, I have seen miles of cabinets screwed into 25s without a problem. Do not use DW scews!
Matt
