Micro-Hydro Enegy: The continuous loop?
| Posted in General Discussion on March 1, 1999 05:47am
I was pondering over renewable energy, and cheap unobstructive ways of achieving it, and I thought of this idea (I shold’ve got a patent first). Can a micro hydro system be installed on a contiuous loop with a low amperage circulating pump? The system would work sort of like forced hot water heating systems. I imagine someone must’ve thought of this before, but it sure sounds like a good idea. I’d be interested in any input.
Britt
  1. Guest_ | Feb 28, 1999 06:16am | #1
    Fred, what important thermodynamic lessons were learned? Perhaps that the second law is true? Why not blow air past a Maxwell Demon and get hot air on one side and cold air on the other?
    1. Guest_ | Feb 28, 1999 06:27am | #2
      *Is this site becoming the perpetual motion site?????Something for everyone!Jack : () )(
      1. Guest_ | Feb 28, 1999 06:40am | #3
        *Yep, I'm with Jack on this one. No way jose, This would be a perpetual motion machine.In laymans terms - the first law of thermodynamics says you can't get something for nothing. The second law says you can't even break even.Now if you want to use a geothermal heat pump to make steam to run a small turbine, then you are on to something. But that darn heat of vaporization is soooo high.-Rob
        1. Guest_ | Feb 28, 1999 08:42am | #4
          *Admittedly knee jerk, but I'll stand by my statement. Just as I did when a coworker told me he was going to run his generator with an electric motor. All you gotta do is give it the iniial spin to get it started.-Rob
          1. Guest_ | Feb 28, 1999 08:47am | #5
            *Rob,Or how about the super efficient new "in room" air conditioners that supposedly cool room air with roomair!Standing on the wrong side,Jack : () )(
          2. Guest_ | Feb 28, 1999 09:46am | #6
            *Fred,I hereby christen thee "Perpetual Fred L".....Las in loopy...... and you sure are perpetual....Politely and in fun, fang-less,Jack : )  )(
          3. Guest_ | Feb 28, 1999 09:51am | #7
            *I am reminded of the great print ad for a T.V. antenna:"Actually pulls signals right out of the air!"Still the funniest ad I have ever seen.Rich Beckman
          4. Guest_ | Feb 28, 1999 10:01pm | #8
            *I think a macro approach might work here. Get a big enough body of water so that twice a day the water rises and then falls. Capture that water while it's up and let it fall back through turbines. Don't know if it would fit in th etrunk though...
  2. Britt_Smallwood | Mar 01, 1999 05:47am | #9
    I was pondering over renewable energy, and cheap unobstructive ways of achieving it, and I thought of this idea (I shold've got a patent first). Can a micro hydro system be installed on a contiuous loop with a low amperage circulating pump? The system would work sort of like forced hot water heating systems. I imagine someone must've thought of this before, but it sure sounds like a good idea. I'd be interested in any input.
    Britt
Rescuing Old Hardware
Whether it’s already in your house or picked up at a flea market, vintage hardware almost always needs help.
  • Townhouse Transformation
