Microlam vs hanger size puzzle.
constantremodeler | Posted in Construction Techniques on June 2, 2008 03:28am
My engineer specified a 5-1/2 x 7-1/4 Microlam beam supported by Simpson  WNP608 joist hangers. All the suppliers I’ve checked say Microlam only comes in 1-3/4″ thickness so we would sister 3 pieces. That makes 5-1/4″ x 7-1/4″. I thought the engineer made a typo but then there is the hanger. It’s pocket is 5-1/2″ wide. Neither Simpson or USP seem to make a 5-1/4″ hanger. I would think the hanger makers and engineered lumber people would be in sync on this. What am I missing?
  1. frammer52 | Jun 02, 2008 05:20pm | #1
    Quick google search showed GP has micro at 3 1/2 in. wide.
    This means your supplier needs to go looking, or you contact engeneer to find out manufactoror
    1. wane | Jun 02, 2008 07:13pm | #2
      confirm the dimension with archy, then hanger with simpson, allot of the hangers they make in a range of widthes, you just specify what you want ..
  2. Framer | Jun 02, 2008 07:24pm | #3
    If your engineer specified a one piece at 5-1/2" wide microlam, then you have to use a one piece 5-1/2" microlam. Your lumberyard is useless, find a real one. Every lumberyard sells 3-1/2 and bigger.You can't just replace it with (3)1-3/4" microlams because they carry a different load than a one piece microlam. Call the engineer first before you order these. It might be alright if you have a dropped beam compared to a flush beam with joist hanging off the beam.
    Joe Carola
    1. timkline | Jun 02, 2008 11:29pm | #4
      joe,
      i'm pretty confident that his yard is correct that the brand name "Microllam LVL" from Weyerhauser only comes in 1 3/4" thickness
      anything thicker than that is "Parallam PSL" also from Weyerhauser
      http://www.ilevel.com/literature/TJ-9000.pdf
       carpenter in transition
  3. Jim_Allen | Jun 03, 2008 01:44am | #5
    I'd be confident to say that the engineer is going to be comfortable using a built up system of three lvls, but you should double check that and get a nailing pattern.
    Typically, if you built up three of these lvls and tried to jamb them into a 5.25" hanger, you'd have a "too tight" fit. I know....the numbers say there will be a 1/4" slop but experience has proven that to be not true.
    Your 5.5" hanger will be perfect for a 3 ply built up lvl beam.
