Mike Smith and his pole barn houses
| Posted in General Discussion on February 9, 2001 04:03am
Since I was hyjacking the other thread, I decided I should start my own.
I got some more pole addition questions.
1) what do you hang the sheathing and drywall on? When building pole barns, I’ve just had a few horizontal nailers between poles to hang sheet metal.
2)If you end up with a crawlspace, What do you do with a 30″ high pressure treated skirt so it doesn’t look like a pressure treated skirt?
3)How are windows and doors installed? I guess I’m too stuck in platform framing to think outside the studded box.
  1. Ryan_C | Feb 09, 2001 04:03am | #1
    1) what do you hang the sheathing and drywall on? When building pole barns, I've just had a few horizontal nailers between poles to hang sheet metal.
    2)If you end up with a crawlspace, What do you do with a 30" high pressure treated skirt so it doesn't look like a pressure treated skirt?
    3)How are windows and doors installed? I guess I'm too stuck in platform framing to think outside the studded box.
  • Smarter Stop Block
  • Square Walls Solo
