Milwaukee worm drive saw leaking oil
JohnWalker | Posted in Tools for Home Building on January 19, 2010 10:59am
I picked up a used 8.25″ 6378 saw and need to change the oil and repair a seepage oil leak on the front end. Where do these typically leak? There is sawdust oil caked on the front red plastic “hood”. The parts manual shows a $0.67 gasket behind it. Are there any other places these saws typically leak because I don’t mind changing an o-ring or $2 gasket while I am in there. Thanks in advance for any advice. John
  1. bubbajames | Jan 23, 2010 04:04pm | #1
    E-replacement parts and toolparts direct are great sorces for parts. I would start with a good cleaning to make sure there are no casing cracks where oil could be leaking from. Good luck!
    popawheelie | Jan 23, 2010 04:32pm | #2
    It sounds like your leak is coming off the arbor shaft.
    There should be seals right behind where you blade sits.
    Does your arbor shaft have any side play?
    The reason I ask is if the bearing behind the seal is shot it would lead to the seal failing.
    Just something to keep in mind.
Drafting the 2027 IRC
  • The New Old Colonial
