Hi,
I was wondering if there are any issues with placing 2 footings right next to each other? Would there be any concerns with placing an 18” footing for a deck right next to an 18” footing for a balcony?
Hi,
Why not just one 36 x 18 footing?
Hi,
Thanks for replying, but I don’t quite understand what you mean. What do you mean by 36x18 footing? Would i use it to support 2 piers & 2 posts that are spaced 18” oc? I apologize if I’m being imprecise...masonry is very new to me so I might be misusing terms
Yes, just pour a 36 inch footing instead of the two. Place the two post anchors where the posts will go. Two footings next to each other would work, too.
Oh wow, didn’t realize that sonotubes get that large.
It seems like the second variant seems to be called a “combined footing”
https://www.civillead.com/combined-footing-definition-and-types/#What_is_Combined_Footing
Thank you very much for taking the time to help me
What does the sonatube have to do with the footing?
Hi,
Perhaps I misunderstood what mikemahan3 said:
“ Yes, just pour a 36 inch footing instead of the two. Place the two post anchors where the posts will go.”
My understanding is this: a support consists of a footing, a pier and a post. A pier is usually cast in a sonotube. However I’ve seen people use the word footing to refer both pier and footing. Since mike mentioned attaching post hardware to the footing I was assuming that he meant that the both the pier and the footing is 36”.
Please let let me know what I’m misunderstanding.
Thanks!
The footing should be rectangular. I've never delt with round footings. Even round piers usually sit on square footings. Yours should be 36" x 18"
People do call all kinds of things footings, They also use foundation. People call all kinds of things imprecise names.
footing is the part that spreads a more concentrated load out so that the underlying undisturbed or properly compacted soil can handle the load.
You could bury a 36 inch sonatube filled with steel and concrete, but that would be more suitable for a cell phone tower. (for an example)
No worries, however, discussion is a good way to learn.
Aligor,
It is my understanding that footings for such like a deck, when within a certain distance which I forget, of another footing (say for the house) must be at the same depth as the original footing else pressure from the new footing will impact the old footing. Thinking 5 feet might be the distance. What some of the other contributors are suggesting is that while your footing has to be of a certain size based on load (the tables give both square and circular dimensions) that does not mean the entire column has to be of those dimensions. So, you do not have to use a sonotube full of concrete the same dimensions as the footing. Might save you a bit a money/work and back labor.
It seems like the second variant seems to be called a “combined footing” https://civiljungle.com/combined-footing/
“[Deleted]”
