Mission Style Doors
Tom69 | Posted in Construction Techniques on March 22, 2009 03:48am
Am building a small kitchen in shaker style (or Mission). Flat rails and stiles anyway.
One upper cabinet will have multipanes of glass. Do muntins need to be square like all else or can I use typical sash cutting bits? If square, how is it done without being too wide and clunky?
Thanks for your help.
  1. Piffin | Mar 22, 2009 03:56pm | #1
    carefuly
  2. DavidxDoud | Mar 22, 2009 04:02pm | #2
    "square"
    well, they should be flat -
    leave you sash bits in the box -
    "there's enough for everyone"
    1. Tom69 | Mar 22, 2009 04:12pm | #3
      OK I'll do "it" carefully. Rabbetting stock with table saw and hand cut the joints?
      1. DavidxDoud | Mar 22, 2009 04:34pm | #4
        I'd rabbet them on the saw - I'm a table saw man - others would use a router table, I'm sure - clean things up with hand/rabbet plane - hand saw, band saw, or router table/miter gauge to do the joints - what specie of wood?"there's enough for everyone"
        1. Tom69 | Mar 22, 2009 04:43pm | #5
          CVG Doug Fir
          1. Piffin | Mar 22, 2009 07:52pm | #7
            fir is real spintery, so use clamps to hold things aligned and firm, and take small passes if using router. I think I'd di it with a thin kerf bald on the TS
        2. Piffin | Mar 22, 2009 07:51pm | #6
          I know a guy who would use a stacking dado with spacer to make that
Installing Prefinished Cabinet Molding
Use these assembly techniques when installing crown risers and molding to minimize visible gaps and nail holes.
