There is a method to do compound cuts for crown molding using a table saw.
Would appreciate an explanation how this is done.
While no home can be completely fireproof, implementing these fire-resistant details can increase resilience.
It can be done.......
Set the saw blade at a certain angle and run the moulding through at a certain angle.....
But why not get a mitre box?
Did you ever try to crosscut a 16' piece of crown mould through a table saw? It's not a pretty sight.
Ed.
*Best method? Yeah, let someone else do it. Even if you build a jig for this all I can think of is the equivalent of twisted metal, ie, accident.But whadda I know.
*Maybe if the table is real small..........
*Gary, Use the same angle/bevel charts that are used when cutting trim flat on the bed of a compound miter saw. The bevel number on the chart should still be good, but since you're cutting on a table saw where the angle on the miter for a 90-degree cut reads "90" versus a CMS, where the angle for a 90-degree cut reads "0", you'll need to do a little math. Simply subtract their recommended CMS miter angle from 90, and set your table saw's miter guide to the resulting number.Tilt the blade the same as you would with a CMS. The bear is that you;ll be flip/flopping stock left and right to conform to the limitations of a table saw setup.It can be done, but with long lengths, you do need off-table support to keep the stock smoothly sliding across the saw bed.Cut a couple of scrap pieces first for inside and outside corners so you can get the hang of which side needs to be up/down/in/out to get a properly cut miter. Label your successful cuts and use them for reference when lining up the real cuts.
*I've cut some fairly long stock on a BT3000, sliding table, roller supports, a clamp and some muscle. Not my idea of fun. I wasn't kidding about the circular saw - would be easier.
*Oh, I don't know....Have you tried it? You oughta try it. Practice with some cheap quarter round. I'd probably build a jig..... or something.The trick is to VISUALIZE. If the crown is for a cabinet, then maybe long lengths won't be a problem.Let me know how it turns out, 'cause I'm not gonna try it!
